Home > Puma (Tdci) > Lock Diff
Page 2 of 2 <12
mse
CapeLandy wrote:
diff lock was on. I always drive with it on when I go off the tar.
Do you think it aint working?? Shocked
No but it/you/tc did seem to be making a meal of it...should have been easier it wasnt even *that* extreeme
That said it did work and you did make it Mike
Post #8007 4th Mar 2009 6:05pm
jst
just watched the video
it depends how you are driving it to is it reacting right.
when it gets into the cross axle and starts to spin a wheel you should then accelerate and keep accelerating until it moves fwd. if you were doing that and it rocked back as in the first couple of attempts all 3 bumps then its not right.
What is more likely is that you got cross axled, started to accelerate, it moved fwd a little, you backed off, TC slowed down a bit, it rolled back, you accelerated again and it kept going like that a couple of times before you backed off then tried again with more momentum.
When it drives off the last bump for the 2nd time is how it should react all the time. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #8030 4th Mar 2009 9:49pm
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
I questioned your diff lock because only 1 wheel appeared to be turning on the first hump (half way through the clip). That said, I can't really see the other side of the car so I guess you were properly x-axle'd at points. Looking at it again, I can see that is the case on the second hump. One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #8044 4th Mar 2009 11:43pm
CapeLandy
South Africa
You are correct - I did back off the gas as I would in the series to try regaintraction. Was my first week of ownership back then.
I have since on many occasions had the system kick in but it does seem still allow a lot of slip before it actually breaks the wheel. I say this looking out the window of the drivers side so I can't tell if the opposite is slipping at the same rate. Puma 110 - gone
Series III 1973 - going strong
Post #8049 5th Mar 2009 6:30am
Page 2 of 2 <12
