Home > My Defender > K90 |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7875 |
You wait until you're tempted by a second weekend Defender! There is no end!! James
2nd Nov 2019 3:07pm |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4789 |
That’s the way to do it, have two then move the accessories from number 1 Defender to number 2 that’s a cunning plan, now I just need to let SWMBO that I would like a second Defender 2015 HT XS 90
2008 SVX 90 2000 XS TD5 90 |
2nd Nov 2019 9:17pm |
The benefit of two is you should have at least one working at all times! James
3rd Nov 2019 8:34am |
Like your thinking James, not sure I can persuade SWMBO that’s a good enough reason 2015 HT XS 90
3rd Nov 2019 9:58am |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3618 |
Fitted today and feeling good. However, there is a knocking from the rear. The top mounting bush doesn’t seem as tight as the Bilstiens that came off, and there is quite a bit of slack. This doesn’t seem right does it? See attached pic. I feel like there should be cup washers either side to squash the bush? What’s the general consensus?
Click image to enlarge |
3rd Nov 2019 4:19pm |
MJN110 Member Since: 18 May 2015 Location: North Yorkshire Posts: 380 |
Click image to enlarge You need to use 2 of your original washers not bilstein ones 2016 Defender Landmark 90 2005 Defender CSW TD5 90XS |
3rd Nov 2019 5:41pm |
Cheers! Haven’t got the original, I’ll make some tomorrow. Does the outside one sit up against the shoulder on the bolt, or go past the shoulder?
3rd Nov 2019 5:47pm |
Will I cause any damage doing about 15 miles on smooth roads? Need to get to the workshop to make some washers.
3rd Nov 2019 5:49pm |
When making up the bottom mount I just made up enough to make the cups snug I thought it would be less stressful on the shock and minimise any side thrust.
I also gave the cups a light coating of silicon grease to ease there preforming. 2016 Defender Landmark 90 2005 Defender CSW TD5 90XS |
3rd Nov 2019 5:52pm |
I am fairly sure it goes up against the shoulder. 2016 Defender Landmark 90
3rd Nov 2019 5:55pm |
Top man, much appreciated.
3rd Nov 2019 6:13pm |
Note the washers I used have the bevel profile towards the shock. 2016 Defender Landmark 90
3rd Nov 2019 6:18pm |
Cheers, but not sure I can see from your pic. If the washer was a bowl, would the rim of the bowl be facing the shock?
3rd Nov 2019 6:32pm |
Yes the bevel/bowl would be facing the shock. 2016 Defender Landmark 90
3rd Nov 2019 6:36pm |
