![]() | Home > Puma (Tdci) > Heated Rear Window |
fuses x2
broken wire in the rubber swan neck between rear door and the D post ![]() Click image to enlarge ![]() Click image to enlarge Last edited by dorsetsmith on 3rd Nov 2019 4:13pm. Edited 1 time in total |
Kevzeboy Member Since: 19 Jul 2014 Location: Cumbria Posts: 88 ![]() ![]() ![]() |
Found this?
( found this? )
sorry do not under stand |
Sorry, pictures didn’t go on.
Got it sorted. The main live to the relay connector was burnt out. Looks like it must have been a sloppy fit. Sorted now. |
add relay connector to the list
Thanks.
MMR1988 Member Since: 29 Oct 2016 Location: Chemnitz Posts: 54 ![]() ![]() ![]() |
In most cases the wiring on the window itself is not working anymore.
My Defender can only heat one stripe from the window and the 3rd brake light is not working due to this issue. I fixed the issue with the brake light and let the window as it is. I use the side mirrors in most cases anyway. |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 2027 ![]() ![]() ![]() |
Remove the 3rd brake light cover and you will probably notice the cover has worn away the track, a repair kit from Halfords for around £10 will fix the issue, I put on about 5 layers. It takes a day to cure
👍👍 [/img] 2023 Defender L663 V8 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
The front heated screen had about 100 mm that doesn’t heat in front of the steering wheel. Would no obvious brakes in the wires?
Any suggestions? |
The only fix for that is a new screen, I'm afraid. Darren
