Home > Maintenance & Modifications > Windscreen wipers keep stopping
Barneyboy
England 1986 Defender 90 2.5 n/a Diesel ST Nato Green
Hi we are visiting friends on Exmoor and have been out this morning they have a 2005 TD5 Defender and the wipers keep stopping in the upright position and a gentle nudge starts them again problem is the kids are eventing tomorrow and they need to tow the horsebox. Any advice as to if there may be something we can try to get them working again please would be great 👍 cheers Paul
Post #800482 2nd Nov 2019 3:44pm
grafty99
Give the wiper spindles a good spray of WD40 or similar after pulling the rubber seals back towards the wiper arms Thumbs Up
Do this with with wipers running (help them along as necessary) they should free up after a good soaking and a few minutes use. Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #800485 2nd Nov 2019 3:56pm
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
I hate to be the doom monger but I had the same problem a couple of months ago , sprayed as Grafty says worked okay until next day then nothing. It turned out to be the motor had ceased sold, so much for maintenance free bearings. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #800488 2nd Nov 2019 4:39pm
Very often these are the symptoms of excessive wear in the wheelboxes, in which case renewal of same is the only effective remedy.
Post #800492 2nd Nov 2019 5:17pm
Barneyboy
Hi thank you all for the advice given weve had the dash off after spraying profusely with wd40 and sadly no change we've taken the wiper motor apart and there are teeth missing from the big cog
So he is going to order a new one shame as we were really hoping to fix it for tomorrow but it'll now be 2 trips with the lorry as they're taking 4 horses. Thanks again for the advice as always it's very much appreciated 👍 cheers Paul
Post #800496 2nd Nov 2019 6:08pm
The wiper wheel boxes are on my to do list this coming year. They aren’t causing problems yet but by that stage they’ve caused a lot of problems.
I know they are worn though.
As Blackwolf said, the wheel boxes I also think are more typical culprits than the motor and the rest of the system.
You often notice many older Defenders with droopy wiper arms, that’s a sign. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #800503 2nd Nov 2019 6:57pm
Barneyboy
Thank you all he is going to put an order in tomorrow for the parts as weve left it All open ready to replace the parts luckily he has another car he can use so it's sat in the barn ready for repairs when they arrive 👍cheers Paul
Post #800529 2nd Nov 2019 10:38pm
