![]() | Home > Puma (Tdci) > Transfer box speedo drive |
windy81 Member Since: 14 Mar 2018 Location: North Wales Posts: 311 ![]() ![]() ![]() |
Not sure if its the same as my lt230, but there was a ridge all round the transducer container thing. I got a screwdriver and used the ridge for purchase. Wasn't easy to be honest.
![]() this sits in to hole with the speedo drive gear with o ring and small seal fitted inside AAU23404 You will find that its corroded in place ( steel and aluminium ) ![]() |
Vitesse Member Since: 21 Mar 2014 Location: Sussex Posts: 402 ![]() ![]() ![]() |
Thanks for the help. I did wonder if it was a case of gently levering it out
I will give it another go at some point. ![]() |
