Home > Tdi > Will a Td5 Transfer Case bolt straight into a 300Tdi?
RobM
Australia 2010 Defender 110 Puma 2.4 SW Chawton White
Guys...
I'm looking to buy a TC out of a Td5 Defender but I'm a little bit unsure if it will simply bolt straight in without any mods. I know the Td5's have a electronic speedo whereas the 300Tdi's don't - will this be an issue?
Rob Cheers.....
Rob
1995 Defender Tdi 110Wgn
2010 Defender PUMA 110Wgn
TRIPS: Meanderingdownunder WikiLoc Trips
Post #799747 28th Oct 2019 6:16am
sako243
By transfer case you mean the LT230? I'm pretty sure they'll simply bolt over.
If you already have the 300Tdi transfer case then the speedo sender can be swapped over. There's normally just a couple of small bolts holding the cable into the transfer case just in front of the handbrake drum. Unbolt those and remove the retaining plate and the cable pulls straight out.
One option is to also swap over the speedo on the dash to an electronic version as well. Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #799752 28th Oct 2019 9:50am
dorsetsmith
Td5's have a electronic speedo whereas the 300Tdi's don't - will this be an issue? No as Speedometer Transducer can be removed
then removing the transfer cases just make a note of there bolts are from as not all same length Exclamation and go though in to the gear box and from gear in to transfer box not all blind hole Exclamation
or swap over the speedo on the dash to an electronic version and add the wiring and plug
http://www.retroanaconda.com/landrover/200...tdi300tdi/
Post #799760 28th Oct 2019 10:17am
RobM
This sounds interesting... My speedo is terribly inaccurate so I like to know more about this mod ?? Cheers.....
Rob
Post #799769 28th Oct 2019 11:15am
RobM
Thanks for the link -- reading it now Smile Cheers.....
Rob
Post #799770 28th Oct 2019 11:17am
jfh
South Africa 2007 Defender 110 300 Tdi SW Chawton White
My 300Tdi came out standard with the electronic speedo. Very nice.
Post #799898 29th Oct 2019 4:37pm
