Home > Puma (Tdci) > Which rear awning
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Which rear awning
So was out in the Diffy today and it was raining cats and dogs.
Thought it would have been useful to have a rear awning so I was protected when rummaging for stuff in the back of the vehicle.
I have Flatdog roof bars to which it will need to attach.
Any recommendations for a decent rear awning which won't require me to sell off a kidney?
I quite like the idea of an aluminium casing rather than a PVC sleeve for containing the awning when not in use
Post #799642 26th Oct 2019 10:54pm
jst
a bt technicians umbrella which has a short leading edge that would butt up to the roof above the door.
not quite what you asked for but a possible solution. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #799698 27th Oct 2019 5:51pm
kmac
hmmm....I've seen someone here has used a garden umbrella, but I don't even know what a BT technicians umbrella is - is it just "an umbrella"?
Post #799720 27th Oct 2019 8:55pm
jst
like a golfing umbrella but has short arms on a 180 face so butts up to a wall, or or in this case. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #799730 27th Oct 2019 10:07pm
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
When it rains BT tech's van up not like the old days of putting up a tent. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #799750 28th Oct 2019 9:25am
kmac
I think an awning would be a more elegant solution.
I've given up on alu casing as this seems to be only available on longer lengths from the likes of Fiamma.
Now a toss up between
Howling Moon Safari Awn 1.4m
Front Runner 1.4m
Arb 1.215M
Any views on the above?
Post #799756 28th Oct 2019 10:05am
athelstan
United Kingdom 2015 Defender 90 Puma 2.2 CSW Montalcino Red
I'm looking for the same thing to keep me dry when the rear door is open. So far I've looked at cheapo canopies from ebay like this:-
https://tinyurl.com/y3yu9wkm
Fishing umbrellas with a curtain, which have a handle long enough to clear the opening - best to Google as there are so many.
Or a large Senz (Dutch) wind resistant umbrella which has the front cut off, a bit like the BT umbrella. These are readilly available in the UK. 2015 90 XS Station Wagon Puma 2.2
2015 Morgan Plus 4
Post #799846 28th Oct 2019 11:26pm
boode
England 2003 Defender 90 Td5 HT Rutland Red
I have a Hannibal rear awning 1.4m square - bought of eBay so not too expensive
Self supporting and gives enough shelter to the back for rummaging or boiling a kettle - the back door acts as a side shelter when open
Post #799893 29th Oct 2019 3:51pm
kmac
Looks good boode. I pulled the trigger on a Howling Moon Safari-Awn - 1.4M wide by 1.8M long. Has legs but is easy to take off the vehicle by just sliding off the rail.
Post #799908 29th Oct 2019 6:44pm
kmac
..dupe
Post #799909 29th Oct 2019 6:48pm
kzycnn
United Kingdom 2003 Defender 110 Td5 XS CSW Oslo Blue
Missed this, so a wee bit late to the party. I have a Howling Moon 1.4 which I used over the back door - found it quite useful. Be aware that the legs and supports come apart on the 1.4 (and are stowed separately) as they are too long to slide into the fitted tubes. This makes it a bit more difficult to put up, but not much. Also, the mounting beam and awning bag are quite long so they will stick out a bit. I trimmed the beam down on mine and 'squeezed' the bag into the remaining space to make it a touch narrower. No drama and still easy to slide off when you don't want it fitted.
Mine is up for sale (complete with side walls) along with its 2.1m big brother although Gary (Wyvern) has 1st dibs.
Have moved up to a 270 degree ShadowAwn from Alu-Cab which is the only reason I'm parting with them.
Tony
Post #799914 29th Oct 2019 7:30pm
kmac
Damn, ordered new one yesterday else would have ben interested in yours.
Post #800027 30th Oct 2019 10:16am
