![]() | Home > Maintenance & Modifications > Mud deep A pillar trims |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21044
Saw these on FB pop up: https://www.mudstuff.co.uk/mud-a-pillar-tr...HFh8ZpYbJ8
Has anyone tried these? They say 20mm extra but real world views are much better. I can’t make my mind up if they’d benefit for cabling or not. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
| donmacn Member Since: 06 Nov 2017 Location: Nth Scotland Posts: 1917
I have them, as I always struggled to get cabling into the standard ones.
As my car was a basic spec 1994 model, I've had to add lots of stuff myself, so the likes of a CB antenna, hands free phone mic; dashcam power; auxiliary rear light; speaker cabling etc etc. I'm quite happy with them - once they're on, you really don't notice that they're not standard. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18058
I'd not seen those, useful to know about them.
| boode Member Since: 11 Apr 2012 Location: Devon Posts: 438
I have the Mud A pillar trims and they are excellent
I have a lot of extra wires for - rear speakers, microphone, positive feeds from the battery - probably about 8 to 10 extra each side With the extra capacity of the Mud trims they fit easily - no more pinched wires for a flattened rear wash hose They also look standard I would highly recommend them |
| Tegner Member Since: 31 Jul 2018 Location: Alnwick Northumberland Posts: 202
Definitely a good buy I have extra cables for GPS/phone and dash cam all contained with room to spare
| macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1139
I wonder if the lower ends reach behind the dash as the original ones do?
Can you see the cables in these corners? I can't make it out in MUD's photos. |
I bought them. Will see how it goes.
Perfect timing for me to spot these. Going by the interest in these I imagine they’ve had a few orders from here alone. ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
no cables visible on mine
Fitted mine the other day, very pleased with them.
They took all the extra wiring fitted behind them which the factory’s ones would not have done any where near. As has been mentioned, once on you’d not notice the difference, exactly the point in them and hid all of my cables even a 6mm physical dia feed. Plus others as well. Keeps everything much neater and tidy. Pics: Click image to enlarge Click image to enlarge Hopefully maybe of interest to others so you can have a proper gander at them. ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
| L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11096
Looking good there Steve
| ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831
I always find that the pinch point is the area around the screw fittings on the standard Land Rover one's. Do this replacements have the same problem? Don't make old people mad.
We don't like being old in the first place, so it doesn't take much to Richard |
| Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3363
Seems a good solution. My wiring has decent space under the standard fitting. What extra stuff are you running through there? WARNING.
This post may contain sarcasm. |
You have to be careful still you don’t trap the wiring behind there.
But there is lots of wiring room down the side of the fixing which makes it much easier too put back safely and securely. There definitely is about the room estimated that they quoted. I’ve got a 6mm video cable behind one and factory wiring plus multiple 1mm2 twin feeds too around 4mm x 2mm. Drivers side is tightest due to factory wiring but they fitted everything I wanted. So in essence as they say, if your new additional wiring is up to 20mm deep then it will be suitable. Unfortunately I didn’t get a photo of the rear but they are exactly the same as factory only deeper. They are easier to re-install and keep the wiring or tubing away from the screw too. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
| All times are GMT |
