Home > For Sale & Wanted > [Wanted] Another odd request: Old Eberspacher Pump/Part
rallysteve
Annoyingly have snapped the pipe stub off the outlet on my D2 Airtronic pump.
Does anyone happen to have an old/no longer functional pump lying around which could yield a replacement for me please? It is the smaller of the two stubs I need (the one that typically isnt available separately Rolling Eyes !).
Thanks in advance,
84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale
Post #799219 23rd Oct 2019 8:05pm
excossack
Would a brake pipe fitting do the job? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #799315 24th Oct 2019 2:34pm
I looked in my old DVD drawer.... but nada.... Rolling with laughter
Post #799395 24th Oct 2019 9:55pm
rallysteve
Rolling with laughter it was worth a try!
Its a strange fitting sadly, thread must be an M4 with a sealing o-ring above. If it was the pickup side i would chance using a bit of chemical metal to seal it up.
As a temporary measure (to make sure the rest of the system works) i have got a larger piece of rubber fuel hose which should just fit over the larger diameter on the fitting. Not convinced on this as a long term solution though.
I did find a pump 'repair kit' on ebay for £17 but i needs to make its way here from Turkey!
Cheers Steve 02' 110 TD5 Double Cab Rebuild Thread
Post #799428 25th Oct 2019 7:17am
