![]() | Home > Td5 > Wheel arch eyebrow |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20977 ![]() ![]() |
Mine from the factory were perfectly flat.
I found after painting they or one I should say had collapsed somewhat. I don’t know if it’s due to flat storage or by sanding pressure, although I don’t sand like Thor and crush it down. I guess it’s a curiosity of semi rigid plastics, it should keep its shape though but they don’t. Unless production quality has gone downhill. It wouldn’t surprise me. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
windy81 Member Since: 14 Mar 2018 Location: North Wales Posts: 311 ![]() ![]() ![]() |
heat gun and a prop to hold it in position ? just a thought.
Dexterdog Member Since: 23 Jun 2018 Location: gloucestershire Posts: 108 ![]() |
Yep, thats what I am thinking. Then might try and cut a piece of plastic to the right size (from the council recycling box) and use solvent weld (plumbing glue) to fix in place behind arch.
Can’t think of much else that can be done |
