![]() | Home > Td5 > Britpart One Piece Rear Drive Shafts |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2231 ![]() ![]() ![]() |
Ive got britpart 2 part rear shafts. Ive broken 3 genuine LR front shafts.
They are supprisingly decent. |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3374 ![]() ![]() |
I fitted standard Britpart drive shafts and drive members, it only cost just over £100 for 4 drive members and two rear drive shafts.
They’ve now done over 40,000 mainly road miles and are still fine, no play. It might be a different story with heavy off road use, but for day to day driving they have been fine. Land Rover wanted over £400 for one drive shaft !! |
Joe the Plumber Member Since: 18 Dec 2013 Location: Midlands Posts: 921 ![]() ![]() |
If, like me, you're not using it for anything heavy, I've fitted used Disco 1 one piece shafts to the rear of my 2014 110. Forty quid or less a pair, delivered, from eBay and they seem to work a treat.
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 548 ![]() ![]() |
Likewise disco ones in mine, but does a lot of heavy towing
I used disco ones for a long while but they didn't last while off-roading with lockers. They are cheap second hand so I didn't bother too much. However now with 35"simexes I invested in Aschroft HD shafts and CV joints. They cost an arm and a leg and some more bit they are strong.
![]() 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
MJN110 Member Since: 18 May 2015 Location: North Yorkshire Posts: 380 ![]() ![]() ![]() |
Thank you all for your views I have now ordered the Britpart one piece shafts. 2016 Defender Landmark 90
2005 Defender CSW TD5 90XS |
Bluericky Member Since: 26 Jun 2014 Location: Cornwall Posts: 647 ![]() ![]() ![]() |
I’ve had the Britpart ones in for a while now and I’m perfectly happy with them .
They come unpainted (the end obviously!) so you may want to budget for some cans of spray as well ! https://www.instagram.com/hustynminepark/ |
Landymatt Member Since: 31 Dec 2018 Location: York Posts: 204 ![]() ![]() |
As above - a few thousand miles, all good, painted the ends before fitting.
Very chuffed to read lightning’s 40,000 miles on these! |
gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 654 ![]() ![]() ![]() |
I used disco 1 half shafts, I have broken 1 off road, but I carry spares as they only cost me £10 each when I go offroading 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r |
The one piece drive shafts seem a really good idea.
Is there a reason why Land Rover would fit separate drive shafts and drive members? |
Tightfistedness. Darren
