![]() | Home > Td5 > TD5 fitted with a DPF, remove and remap recommendations. |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2225 ![]() ![]() ![]() |
Interesting. May be wrong but a certified DPF on a TD5 is very expensive indeed
Its not likely the ECU would have been touched to allow for a DPF as TD5s never had them. However could br worth giving Gareth at Empire a call (Colchester, Essex) or Gigglepin 4x4 (Sevenoaks). Used them both many times and both do a great service |
Alextd5 Member Since: 11 Feb 2017 Location: Gloucestershire Posts: 322 ![]() ![]() ![]() |
It might have a tailored map, unlikely but unsure. Does the DPF have any pipes or wires coming off it?
Smolyhoke Member Since: 22 Aug 2019 Location: Kent Posts: 4 ![]() ![]() |
Thanks for the replies.
Yes, bankz, it was a LOT of money according to the lady I bought it from who used it as a business vehicle. Unfortunately she wasn't able to tell me any more about it other than it saved her £3k a year in fines/charges if I got that right. I'm no LEZ expert ![]() Thanks for the recommendations, I did see Gigglepin on the web, would Empire be your first choice? Yes, Alex, it has the full kit and kaboodle of a wiring loom integrated into the vehicle and a display with menus in the cab, proper commercial stuff and very expensive looking from a company called HJS (Abgas-Systeme Exhaust Systems) |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6698 ![]() ![]() ![]() |
Might be other Td5-related issues making it sluggish - e.g. stuck wastegate rod or dodgy MAF.
Yes, Martin, I don't doubt that these things need checking too after reading through many posts about slow TD5s and I'll get to them too.
I just think the fact it is putting out zero emissions must mean that there is a serious amount of back pressure from the exhaust to do that much filtering that the original build wasn't designed for. Long term, it gives me some concerns. Thankfully my TD5 only has done a few thousand miles since the DPF was fitted. Also, back to your point, I wonder if the DPF would cause more sludge and back-up although I have no evidence right now, just chewing the cud on it. |
