![]() | Home > Puma (Tdci) > 2.2 Turbo actuator and MAF connector repairs |
Are the wires the same colour not for the VGT or the MAP
MY 2012 2.2 ![]() Click image to enlarge VGT PLug part number YPC909760 plug pins part number YPL1002230 link to the wiring below for MY 2012 https://1drv.ms/b/s!AtZSoWFHDgnGlB8iSFfsA9JN_EFj?e=OehsdB VGT PLug same part number for 2.4 and 2.2 My 2008 2.4 ![]() Click image to enlarge Last edited by dorsetsmith on 14th Oct 2019 2:29pm. Edited 4 times in total |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 688 ![]() ![]() ![]() |
Hard to tell - this is the kit for the 2.4 turbo /VGT
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6682 ![]() ![]() ![]() |
The turbo actuator connector is the same on the 2.4 and 2.2
Wiring colours changed for the 2.2 but the connector is the same ![]() ![]() ![]() |
Thanks - guess that will have to be the solution but would have liked to maintained the right colours.
I could do you a repair kit in 2.2 colours for £35+VAT
The Land Rover LR020663 kit is £24+VAT RRP ![]() ![]() |
Thanks Martin. Would that include the ferrite part? Is it needed?
Hmm forgot about the ferrite.
I could always supply the correct coloured wires with terminals on and swap them over into the LR kit. ![]() ![]() |
shame we haven't got impedance information for the ferrite used i.e. 33Ω at 25MHz
Thanks Martin. Am away for a couple of weeks so will let you know once I get back.
I have ordered the parts from Martin and once received will be taking to local autoelectrician for repair.
I note on the technical bulletin https://public.bellautoservices.co.uk/down...020663.pdf for replacing damaged turbo actuator connector/wiring it requires fault clearing. I have also read somewhere this is needed to calibrate the actuator position? I have no DTC showing and have no engine issues, only doing this a preventative measure, is it reasonable to assume I can get away without doing this? I doubt my autoelectrician will have the set up for this action. |
So got the new pigtails fitted today. Once I get chance in day light I will post a photo of the tidy job they did. At a quick glance with a torch I couldn't see anything of the repairs.
Here are pictures of the old connections. Nearly all the wires were damaged. ![]() Click image to enlarge ![]() Click image to enlarge |
Wow, that's a little worse than I had imagined.
Do you have any thoughts on how or why it's happened? Off to check mine... |
I can only think it is a combination of heat, vibration and maybe not enough flex in the cables.
The engine has had no major surgery to require them being removed or disturbed. |
