Home > Maintenance & Modifications > Rear Diff Seal Persistent Leak
IandelaMare
United Kingdom 1993 Defender 90 200 Tdi HT Arrow Red
Hi,
I am new to Defenders. I have a 1993 90 200TDI.
I have a persistent rear diff seal leak. I've had two new seals and a new flange. I noticed that the axle breather was blocked so I replaced that. Would the blocked breather have blown the new seal?
Thanks
Ian.
Post #798041 14th Oct 2019 10:05am
BaronDefenders
United Kingdom 2004 Defender 90 Td5 CSW Santorini Black
Yes, very likely! If the breather is blocked, the air, as it heats up and increases pressure, will take the path of the least resistance. Which is often the pinion seal. Charlie
1949 Series 1 80 (SOLD)
2002 Td5 90 (SOLD)
2008 Freelander 2 (SOLD)
1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored)
1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE)
2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK)
2012 Puma 110 Zermatt Silver (Overlanding Build)
Instagram: @BaronDefenders
Post #798047 14th Oct 2019 11:01am
See if the UJ's on the props are getting hot, in particular nearest the leak.
If you still can't tell take the prop off and check them.
I had pinion oil leaks time and time again, and in the end the culprit was a failed UJ cup, and roller bearings.
Nearest to that was the culprit rear diff pinion oil seal and diff case nose.
Breather is worth checking though too. WeWillWin🇬🇧🇺🇸
Post #798049 14th Oct 2019 11:18am
IandelaMare
Hi, thanks for the replies.
Re: Seal - would the seal continue to leak once a new Breather pipe has been installed (would the seal have been compromised by the blocked pipe?)
Re: UJs - I have a chattering sound from the back when driving - would that be related?
Mnay thanks again
Post #798053 14th Oct 2019 11:29am
BaronDefenders
If the seal continues leaking after replacing the breather then either the seal has been damaged as a result, or, the problem lies elsewhere. Best eliminate all possibilities and then get hold of a new seal - from memory, I don’t think they’re expensive. Charlie
2002 Td5 90 (SOLD)
Post #798055 14th Oct 2019 11:36am
Highly possible yes.
Often coupled with excess gearstick vibration or movement I found. WeWillWin🇬🇧🇺🇸
Post #798056 14th Oct 2019 11:38am
IandelaMare
Great, thanks!
Post #798057 14th Oct 2019 11:38am
IandelaMare
Cheers! I will check all that out. Thanks both for such speedy responses!
Post #798059 14th Oct 2019 11:44am
I have had repeated problems with aftermarket flanges (not Britpart which I wouldn't touch with a barge-pole, but "reputable" aftermarket ones), due to poor machining tolerances resulting in the bearing surface for the seal being either out-of-round or not concentric with the centre bore. This will destroy the seal out in a very short time.
The former is easy enough to check with a micrometer, the latter is much harder to check.
I have not found similar problems (yet) with genuine parts, but I believe that a genuine flange is now absurdly expensive.
Post #798064 14th Oct 2019 12:02pm
IandelaMare
OK, that's good to know, thanks.
Post #798065 14th Oct 2019 12:04pm
IandelaMare
£245 yikes!
Post #798066 14th Oct 2019 12:11pm
Yes, those pinion flanges are blooming expensive.
It was genuine on mine, before and also after a new one also genuine and it still persisted on leaking.
I can only but assume the failed UJ cup and roller bearings were causing a non concentric imbalance load on the pinion flange and thus seal.
You couldn't tell the UJ was knackered with it in situ either hence why it took so long to find and check.
Once I replaced the UJ's then I had the pinion oil seal repaired for me it's been fine since.
I suppose the bolt could be loose too, another possibility but not massively common but it has happened before.
As blackwolf mentioned regarding the flanges not always being true, that's another concern.
Surely they are not fit for purpose if sold like that.
Square peg, round hole springs to mind.
Out of interest, is the noise in motion?
Is it worse at lower speeds or higher speeds?
If you put the handbrake on on an incline then release the foot brake is there a lot of movement? WeWillWin🇬🇧🇺🇸
Post #798080 14th Oct 2019 12:58pm
Mo Murphy
Inspect the drive flange seal land carefully for scoring, if scored it will not seal, new seal or old.
50 Shades of Pennine Grey
Post #798091 14th Oct 2019 2:24pm
IandelaMare
Thanks all.
Noise is intermittent. Starts up when rolling, like a chattering bearing or loose something or other. It's infuriating.
I think new UJs, check flange and new seal is the way to go
Post #798098 14th Oct 2019 3:22pm
LR90XS2011
chattering could be handbrake dragging slightly DEFENDER 90 TDCI XS,
Post #798122 14th Oct 2019 5:04pm
