Home > Td5 > td5 turbo feel pipe replacement |
Ndamico Member Since: 03 Apr 2019 Location: Canada Posts: 52 |
i found a thread where someone indicated remove the oil filter housing- i assume the spin on, not the centrifugal. if I do this i'm sure there is a gasket in there. looks to be LVH100230. do i need to replace it or is it reusable? assuming this is even the correct course of action. 04 110 TD5
13th Oct 2019 7:16am |
LVH100230. is one use crush gasket, new gasket for replacement
13th Oct 2019 7:29am |
is pulling the oil filter housing the correct way to remove the banjo bolt? 04 110 TD5
13th Oct 2019 7:36am |
if remover oil filter housing you will be able to remove the banjo bolt and use one replacement gasket, remove Centrifuge Oil Filter Housing Assembly you will be removing bolts fixing Oil cooler assembly too and more replacement gasket LRJ1000000 plus O ring ERR7098
13th Oct 2019 7:56am |
