Home > Series Land Rovers > New to me Series 2 |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16809 |
Ah, OK. Vehicles first registered prior to 1965 can incorporate the indicators into the front sidelights and rear tail lights, but the sidelights must be white/clear in colour and the tail lights must be red. In order to be legal therefore your front sidelights and indicators must be white/clear, not amber/yellow. (The only other colour allowable for a front sidelight is yellow, but only if the light is incorporated into a headlight which is only capable of showing a yellow light - remember all those old French cars in the '60s and '70s)? Although sidelights are tested as part of the MOT it seems from a cursory examination of the regulations that although the function, position, integrity, and switching is checked, the colour is not. If I might say so the vehicle looks better already without the bumperettes, and would look better still with white lenses on the front position lamps. (Usual caveats apply, I am not a lawyer so please check this information. Similarly I don't wish to be prodnose or killjoy, but I wouldn't want you to me pulled over in your new pride and joy and fined for a trivial infringement you were unaware of.) |
7th Oct 2019 7:30am |
Barneyboy Member Since: 19 Nov 2014 Location: Oxfordshire Posts: 1582 |
Hi blackwolf no not at all i would rather here this information than find out on the side of the road i have got some clear lenses so will sort that out definately. so the indicator on the front is ok to flash white/clear or do i have to get one with 2 bulbs inside ie orange and clear, totally agree on the front now even tash commented when she saw it yesterday that it looks much better and legal Many Thanks Paul
7th Oct 2019 8:13am |
Use a standard twin-filament 21W/5W clear bulb in a single housing with a clear/white lens. The 5W filament should be the sidelight, and the 21W filament the indicator. This way both lights will be white lights, but with the indicators flashing it is a brighter white flash than the sidelight.
It is actually probably exactly what you have now except for the colour of the lens. |
7th Oct 2019 8:28am |
Hi blackwolf thank you very much for the advice its very much appreciated cheers Paul Tash n Barney
7th Oct 2019 8:36am |
Hi Today I’ve been busy with our new series 2 (Major) I’ve purchased this week 2 x high back outer seat backs and 2 x Securon 4 point harnesses and a lap belt for the middle seat for Barney our black labs harness to click into, also I have put a full set (3 doors) of new door seals which I managed to get free from work and they fit really well, and fitted 2 wing mounted mirrors and there were a few holes in the tub and bulkhead that I’ve put rubber grommets in, all in all a very productive day, tomorrow I’m going to fit a rear work light and use it for reversing as well I have just got to get a switch that lights up to warn me it’s on 👍 cheers Paul Tash n Barney
Click image to enlarge Click image to enlarge Click image to enlarge |
12th Oct 2019 4:53pm |
Hi not much to report other than using it everyday for my commute to work (although not the last couple of weeks as on furlough leave now) it’s been reliable and a pleasure to drive, there was one thing that bugged me though and that was the modified bulkhead which stood out even more as it was bright red so over the last few days I’ve tidied it up and added a couple of covers over the single windscreen motor (later addition) and below the windscreen, I’m unsure why it was modified but I was informed when I bought it that at some stage in its life it had a much bigger engine fitted.
Before Click image to enlarge After Click image to enlarge |
5th Apr 2020 9:33am |
That looks very smart and in-keeping. Darren
5th Apr 2020 11:44am |
Thank you Darren much appreciated I’m much happier with how it looks now cheers Paul Tash n Barney
5th Apr 2020 4:59pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10427 |
Much better, good work you have done there 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton. |
6th Apr 2020 8:23pm |
Hi Clayton thank you I am so pleased I’ve done it, I’m intrigued to know why it was modified in the manner it was as I’ve had a series with a V8 in and the only modified part of the bulkhead was the bottom whereas this one is just below the windscreens frame and at the bottom cheers Paul Tash n Barney
7th Apr 2020 6:09am |
Hi been out on the Paddock’s this morning clearing a very small part of a large tree 2 loads so far cheers Paul Tash n Barney
7th Apr 2020 11:16am |
Nice to see it on the grass and earning it's keep
The only thought i had about your dash, is to see if you can find any of the previous owners, perhaps an ad in one of the landy mags 1996 Golf Blue 300Tdi 110 Pick up. Keeper. Clayton. |
7th Apr 2020 7:12pm |
Hi Clayton that is a good idea externally the bulkhead looks as it should it’s the inside that intrigues me cheers Paul
8th Apr 2020 6:48am |
That's one of the problems of being intrigued, you have to find out the answer, it will get the better of you not knowing why 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton. |
10th Apr 2020 7:51pm |
