Home > Maintenance & Modifications > Home Made Rivnut Tool
Page 3 of 3 <123
GrouseII
United Kingdom 2008 Defender 90 Puma 2.4 HT Coniston Green
Thanks
It was good to see I am not the only one having trouble so have splashed out on a short arm riv nut tool as Mike suggests.
Its funny how when you buy a Land Rover your tool box grows almost weekly!
Also, curious to notice there are over 35k of views for this subject, that's a lot of riv nuts!
Grouse 2
Post #699534 9th Apr 2018 9:17am
foggydave
United Kingdom 2014 Defender 110 Puma 2.2 USW Bonatti Grey
Thanks for such an interesting post
One suggestion though is that for the tightening nut use a longer nut. The one in the picture is called a stud connector and is approximately 4 times longer than a standard nut so is far less prone to thread shearing. Also I used an Allen bolt as they are much harder than standard steel bolts.
Stud connectors are available from Screwfix and Tool Station. If you live in Leicester go to a small shop called All Screwed Up on Cavendish Road. An absolute Aladdin's cave of all types of nuts, bolts and fixings.
If an Allen screw is not available I would also use a fully threaded stainless steel screw/bolt as the thread will not shear as easily as normal steel
Post #735636 18th Oct 2018 9:58pm
Si
Any recommendations for a rivnut tool? Thanks
Post #796758 4th Oct 2019 10:51pm
nitram17
miker wrote:
I think your problem lies with the nut and bolt, not the rivnut.
Most coach bolts are 4.8 grade at best, which is roughly comparable to mature cheddar.
I've done loads the DIY way using decent 8.8 bolts and grade 8 nuts.
Equally a short armed rivnut setter is only £35 on Amazon and works well!
Memfast do a great tool that will last a lifetime!I suppose it depends on how much rivnut work you do!
Post #796763 5th Oct 2019 2:28am
Eduardo
Some time ago I bougth this one (from China)
You should use with a cordless screwdriver
Very good results, only take care of the force applied to the rivnut
Cheers Eduardo
Post #796866 5th Oct 2019 10:57pm
nitram17
sorry forgot the link:
https://memfast.co.uk/shop/Vprod1.asp?cat=2258004632
One of the best rivnut tools around and good for confined spaces ..expensive but willl last a lifetime!
Post #796871 6th Oct 2019 12:00am
Si
Thank you.
Post #796879 6th Oct 2019 5:59am
I've had a Bralo hand setting tool for years, which works absolutely fine. Ironically though, I've just ordered a cheap long-handled tool because the design has the head 'end on' rather than at 90 degrees, as I need to set a handful of rivnuts in a confined space.
To be honest, unless you're doing hundreds then any of the cheapish hand tools will probably do. Darren
Post #796889 6th Oct 2019 8:57am
nitram17
Very true LRA... i do like a good tool though Very Happy and the memfast one isvery good for confined spaces.
I think i might form a north east branch of tool buyers anonymous Embarassed as i am a sucker for a shiny new tool!most of which get used once then fill space up in the shed but the memfast rivnut tool is not one of them!
Post #796938 6th Oct 2019 3:26pm
lonewolf
United Kingdom 2010 Defender 90 Puma 2.4 CSW Zambezi Silver
https://www.spyderindustries.com/blogs/new...rivet-nuts
Check this out for a home made rivnut tool........similar to what’s been mentioned but simpler I think?
Post #888185 27th Feb 2021 9:43pm
Lunar Landy
United Kingdom 2003 Defender 90 2.5 TD HT Bonatti Grey
Rivet nut tool
Hi All, I’ve tried a home made rivet nut tool to fit a rear step on my TD5 2003 but not joy, perhaps my technique is wrong or my spanner’s are not long enough, can anybody recommend a manual rivet nut tool that’s not crap but something that’s fit for purpose, considering it may only be light usage?
Thanks
Post #1050282 30th Oct 2024 5:46pm
To be honest now I've discovered them the only manual rivnut setting tool I'd bother with is the Dafra DRNT512, see https://dafra.co.uk/home.html
It's a blisteringly good tool which sets just about any rivnut or rivstud you're likely to need, and does it consistently and flawlessly. The only possible downside is that it isn't cheap, but the best tools seldom are.
Post #1050285 30th Oct 2024 6:41pm
Mo Murphy
M10 steel rivets require some considerable force to pull up properly in my opinion. The hex rivnuts in the rear crossmember particularly so. More than you can apply with a couple of spanners.
The best way is with an air tool.
50 Shades of Pennine Grey
Post #1050289 30th Oct 2024 7:15pm
The tool I linked to in the post above will easily set M12 steel inserts with no difficulty, and the first job I used it for required 20 M10 steel inserts. No problem and very quick (and a fraction of the cost of an air tool).
It really is a very good tool.
Post #1050306 30th Oct 2024 11:44pm
Page 3 of 3 <123
