Home > Td5 > wipers
dave geldeard
England 2002 Defender 90 Other HT Alpine White
wipers
wipers was not working properly on intermitent, now stopped all together poping fuses replaced the wiper stalk still the same any ideas would be welcome cheers dave. Confused
Post #795590 28th Sep 2019 12:48pm
mk1collector
Wiper spindles through the bulkhead probably seized. Pop the rubber cap of the outside and spray with copious amounts of wd40 while working the wipers. Ray
My build thread
Post #795651 28th Sep 2019 7:03pm
ginjez
2011 Defender 90 Puma 2.4 ST Santorini Black
Ooh hello stranger, not seen for ages then twice in one day Rolling with laughter
Post #795657 28th Sep 2019 7:31pm
mk1collector
Rolling with laughter was that you on Leeds Road? I wasn’t sure because I didn’t have my glasses on Rolling with laughter Ray
My build thread
Post #796573 3rd Oct 2019 6:52pm
MJN110
United Kingdom 2016 Defender 90 Puma 2.2 Landmark LE Montalcino Red
This happened to me recently and I ended up having to replace the spindles and drive to them as i was unable to free them up with WD40.
To replace them is a lengthy job involving stripping out your dashboard so allow plenty of time to do it.
If you do a search under wipers there is a lot of good advice on completing this job.
I t is worth replacing the wiper park switch whilst in there as a precautionary measure whilst the dashboard is stripped down they are known to be a problem. 2016 Defender Landmark 90
2005 Defender CSW TD5 90XS
Post #796619 4th Oct 2019 6:33am
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Re: wipers
Don’t use WD40 on your spindles unless it's their penetrating oil. Be sure to use a good penetrant, original WD 40 is useless as a penetrant. Good luck! Thumbs Up 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #796693 4th Oct 2019 3:16pm
dave geldeard
Cheers for the replys dave.
Post #796738 4th Oct 2019 7:54pm
lightning
Had to replace both spindles on my 110 TD5.
Make sure you fit genuine LR parts. I found that the rubber sealing boots on aftermarket ones didn’t stop water ingress to the spindles.
The job takes a while but it’s not difficult.
Post #796744 4th Oct 2019 9:07pm
MJN110
When i replaced mine I packed the cap and external spindles with corrosion block water proof grease. 2016 Defender Landmark 90
Post #796824 5th Oct 2019 6:57pm
