Home > Td5 > Removing safari snorkel
Mike c
England 2004 Defender 90 Td5 CSW Belize Green
Hi all, in anticipation of removing this from my 90, what would have been removed from the standard air intake ducting when it was installed? Aside from the standard side vent cover that is. Just wondering what standard parts I need to source first to get it back to standard.
Thanks
Mike
Post #795013 25th Sep 2019 11:15am
I think you about covered it, just the outer grill Thumbs Up QRZ 2e0vpf
Post #795059 25th Sep 2019 3:37pm
Bluest
There'll be three bigish holes in the wing were the snorkel is bolted through that you'll beed to cover or fill somehow 2007 110 TDCi Station Wagon XS
Post #795070 25th Sep 2019 5:04pm
Mike c
Ok, thanks to both, sounds like I don't need to get any more parts other than the vent Thumbs Up Yes the holes in the wing, thinking about some blanking grommets at the moment as best option and maybe paint them the body colour.....
Post #795081 25th Sep 2019 5:58pm
Mike c
As an update, and for others wanting do the the same with a td5, if you have a genuine safari snorkel you will need a lower air intake pipe section and an upper part that connects to the vent hole that would have been removed, plus the vent cover. Obviously they all differ slightly depending on what snorkel you have and engine.
Post #796558 3rd Oct 2019 4:55pm
seriesonenut
Hi Mike. Post some photo's when done if you get a chance Thumbs Up 1984 One-Ten CSW
2010 XS USW (sold)
1957 Series One 88 diesel
1958 Series One 88 4x2
Post #796599 3rd Oct 2019 9:37pm
Mike c
I will do Richard, or pass the information onto Alan for you. Unfortunately it looks a real pig of a job to get to the bolts on the inside of the wing from the engine bay.
In the meantime I will need to get the pipe sections and vent, so may be a while before I actually remove it.
Mike
Post #796627 4th Oct 2019 7:57am
