Home > Td5 > Another Td5 with belt chirp !
Page 4 of 5 <12345>
BaronDefenders
United Kingdom 2004 Defender 90 Td5 CSW Santorini Black
Hi Alex,
That’s funny you mention the DMF! I did wonder if that could be the issue and the sound was resonating. I do get the growl/moan from the bearing on a cold morning and it does “hunt” for idle when coming to a stop when warm - something I think is related to wear in the DMF. Charlie
1949 Series 1 80 (SOLD)
2002 Td5 90 (SOLD)
2008 Freelander 2 (SOLD)
1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored)
1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE)
2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK)
2012 Puma 110 Zermatt Silver (Overlanding Build)
Instagram: @BaronDefenders
Post #796155 1st Oct 2019 10:34am
geobloke
The hunting for idle rpm is also indicative of the flywheel sensors wiring being contaminated by oil and dirt, a faulty sensor, a failing fuel pressure regulator (FPR), a dirty fuel filter a failing or contaminated MAF sensor or that your engine is in need of a good flush and fresh oil.
The "growl" when cold is not necessarily the DMF failing as it could be any one of the bearings in the gearboxes, the release bearing, spigot bushing or even crankshaft bearings.
In my case the DMF managed over 200k miles and was only replaced "as I was in there anyway" replacing the clutch and believe me when I say my Defender is no "pavement princess", as my Canadian friends would put it. Ironically that clutch failed 18 months later (it was a valeo twinned with LR HD release bearing, now replaced with a LOF clutch) and the growl was actually the main-shaft support bearings in the R380 gearbox...
A growl in the transmission is really difficult to diagnose and the point being is resist the temptation to jump to the DMF being at fault they really do not go wrong as often as the internet makes out.
Now belts chirping that is an entirely different kettle of fish and quite frankly it sounds like I am torturing fairies under the bonnet when shutting down the engine... Fan pulley bearing is getting a little worse for wear... #itsatd5life Rolling Eyes
Post #796170 1st Oct 2019 12:35pm
BaronDefenders
Interesting what you say about the idle hunting. Whether my symptoms are in fact hunting I’m not 100% sure. The car shudders a bit as the idle settles down and you can hear the turbo whistle matching the vibrations. It probably is the hunting issue to be honest. It might be that the sensor and wiring needs a good clean so I’ll give it a blast with contact cleaner tomorrow. The FPR, MAF, fuel filter, and oil are all new/functioning as they should. So perhaps it’s the crank sensor but whilst it’s working the rest of the time, I’m minded to leave well enough alone.
As for the growl, it’s only when the clutch is held down and it first appeared after descending an incredibly steep and tight road in the Alps last summer. There’s was plenty of clutch action involved Whistle So I’m minded to say that’s possible the release bearing that’s seen better days Charlie
2002 Td5 90 (SOLD)
Post #796176 1st Oct 2019 12:54pm
geobloke
Ok if the growl is related to your clutch pedal then it is almost certainly the clutch release bearing. If and when you decide to change your clutch I can highly recommend the LOF power spec clutch kit mated to the standard DMF. Works exceptionally well.
Post #796187 1st Oct 2019 2:15pm
BaronDefenders
I'm planning to put a new LOF clutch and DMF in next year. We've got an LOF clutch in our 2.2 110 and it works beautifully Thumbs Up Charlie
2002 Td5 90 (SOLD)
Post #796188 1st Oct 2019 2:16pm
Alextd5
United Kingdom 2006 Defender 90 Td5 XS CSW Bonatti Grey
Do you have a video ?
I think mine is dmf, or the release bearing. Normally the spigot which can cause the growl. Crank bearings were on my mind.. but I’m optimistic it’s not!! Only done 80k and always been over serviced. However potentially any part can fail serviced or not.
BaronDefenders wrote:
Paul, I have the same noise on my Td5 as in your first video! I haven’t got a clue how long it’s been making this noise for. Possibly for the entire time I’ve had the vehicle. Having spent a week around two other Td5s I thought mine sounded different at idle slightly. The vehicle performs beautifully and for 152,000 miles it’s about as tight as one with 52,000 miles. So I’m at a loss as well Neutral
Post #796230 1st Oct 2019 7:01pm
BaronDefenders
I can try and get one of the engine at idle tomorrow when I service it. But from memory, it sounds exactly like Paul’s first video that he posted. Charlie
2002 Td5 90 (SOLD)
Post #796239 1st Oct 2019 7:20pm
Paul V.
Netherlands 2004 Defender 110 Td5 SW Auto Zambezi Silver
Does your 90 have an airconditioning barondefenders ?
Ifso, would you switch it on when you allready hear the knocking sound?
When I do this, the knocking sound is gone.
So that means, in my opinion, that when you are asking for more power (airco pump on) the ecu gives the injectors a little longer opening time.
By the way, we drove more than 1250 miles after changing injector 1 and changing the seales and plates of the other 4 injectors.
After those the knocking sound came at idle and coolant warmer than 75 degrees.
I will check the cables and crankshaft sensor as Geobloke says.
And will test a new sensor.
To be continued.
Post #796243 1st Oct 2019 8:06pm
BaronDefenders
Paul, no mine doesn’t have aircon.
However, I think I’ve noticed that at full steering lock the noise disappears.
I think my next steps will be to replace the engine oil and filters tomorrow and then run some premium fuel, fuel additive, or snake oil through the system. Charlie
2002 Td5 90 (SOLD)
Post #796245 1st Oct 2019 8:15pm
Alextd5
Paul
Is it possible your defender made this noise before the injector failed? Maybe you didn’t take much notice and now since one failed you listen to the engine note more ?
Mine has A/C, when I turn on the knock does become less obvious.
Post #796246 1st Oct 2019 8:17pm
BaronDefenders
I feel like mine has been making this tap/knock at idle for the last 2.5 years and nearly 30k miles, and thus probably since before I owned it. I’m just more aware of it now having spent a week around 2 other Td5s that sounded different.
If both of yours, Alex and Paul, quieten down with the air con on and mine goes quiet at full lock it would suggest that a slight increase in load is enough to silence the offending item. So, and I’ll happily be corrected, I can’t imagine it being something fatal (fingers crossed) Charlie
2002 Td5 90 (SOLD)
Post #796248 1st Oct 2019 8:25pm
Alextd5
We now have a few defenders making this noise. Like you I believe mine has done it for at least a two years, but I think it’s developed more and concerned me due to this.
But I agree I started listening more to mine after driving other td5’s.
I think I will replace my dmf etc, as it becomes far noisier when the pedal is held at a certain point.
Post #796252 1st Oct 2019 8:37pm
BaronDefenders
Sadly I can’t tell if mine has stared making more noise as the exhaust is loud enough and I’ve removed the engine cover recently. So the whole thing is just an orchestra of diesel noises!
I’ll have a good listen and mess around tomorrow arvo Charlie
2002 Td5 90 (SOLD)
Post #796253 1st Oct 2019 8:40pm
BaronDefenders
So I’ve serviced the Td5. Before and after the service there was no noise Rolling Eyes So either I was imagining it (possibly mine’s just noisy without an engine cover compared to others) or it’s only something that occurs once the engine is up to temperature or on the hotter side of things Charlie
2002 Td5 90 (SOLD)
Post #796367 2nd Oct 2019 6:35pm
geobloke
Out of interest how are the injector tolerance values at idle both cold and at temperature?
Post #796521 3rd Oct 2019 10:46am
Page 4 of 5 <12345>
