Home > Td5 > Td5 leak |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 539 |
That isn’t your water pump, in those images there is front of head, fan belt tensioner and vacuum pump/alternator assembly. Check the oils isn’t coming from the oil feed or return pipe for the vacuum pump. The seal can also go on the vacuum pump between the vacuum pump was and alternator. This is the same as a Toyota part 29341-64130 there is a Nippo Denso part number but it is not available.
Also check your front camshaft seal part number LDI100030. The rocker cover gaskets are prone to leaking, I changed mine and the ‘top hat’ seals which the bolt go through and all is good now. Cheers Will 2005 90 XS 1954 86'' Series 1 tilt |
2nd Oct 2019 6:35am |
Ndamico Member Since: 03 Apr 2019 Location: Canada Posts: 52 |
Cleaned it all up. The cam cap seal is loose. Have a new oring on order. Made a aluminum brace to help hold it in place. 04 110 TD5
3rd Oct 2019 1:54am |
