Home > V8 > new cam
tolley
United Kingdom 2006 Defender 90 Td5 CSW Oslo Blue
new cam
anyone fitted a new cam to a 3.5 also chain , lifters any good info help would be Thumbs Up
Post #796237 1st Oct 2019 6:19pm
DonH2000
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Santorini Black
Hi I did this in my V8 Discovery 1 some 7 years ago and got all the bits from RPi Engineering. Could not believe the slack in the old cam chain when it was removed!
Just take your time and label everything as you take it off! Cheers Don.
Post #796299 2nd Oct 2019 7:47am
Make sure you submerge the followers in oil for a day or so before fitting. instagram @v8_scumbag @green_lane_escapes
Post #796316 2nd Oct 2019 10:10am
V8GPC
seems useful
http://thebritishcar.com/showthread.php?90...tall-guide
Also i think you need to run at 1800 to 2000 rpm for 20 mins or so that the camshaft can harden.
(this was mentioned on Wheeler Dealers when they did a cam change on a V8 ).
Others more knowledgeable than me should be able to confirm.
Post #796323 2nd Oct 2019 11:25am
oneten110
The Rover V8 is stone age simple and very easy to work on.
Changing the camshaft and valve train is complicated only by the quantity of pushrods, cam followers and remembering to number all of them.
Assembly lube for the new camshaft is essential to protect it during initial start up. It is not a Defender, it is a One_Ten
Post #796381 2nd Oct 2019 6:41pm
tolley
I was thinking of renewing the camshaft ,tappets , timing chain , push rods and rocker shafts and thing else I should look for.
what would a it cost to get this done by a recondition shop , if I cant find the time to do it ?
Post #797112 7th Oct 2019 2:17pm
oneten110
You should also consider replacing the rockers, camshaft chain wheel, crankshaft chain sprocket, any oil seals you disturb, rocker cover gaskets, flame traps and dependent upon the type you have, the cylinder head bolts. It is not a Defender, it is a One_Ten
Post #797128 7th Oct 2019 3:44pm
tolley
https://shop.v8engines.com/piper-camshaft-...-245-p.asp
Thumbs Up
Post #797151 7th Oct 2019 5:45pm
Site Copyright © 2006-2020 Futuranet Ltd & Martin Lewis
