![]() | Home > Puma (Tdci) > Xdefend pedal lock for Puma |
Julie Member Since: 07 Oct 2017 Location: Nantes Posts: 588 ![]() ![]() ![]() |
This one will fit
https://4mud.co.uk/safe-t-pedal-security-device-review/ |
ParabolicSwivel Member Since: 13 Nov 2013 Location: Hertfordshire Posts: 42 ![]() |
Yep I’ve seen that one but I like the way the xdefend is fixed to the floor so no need to find a secure place to stow it.
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1124 ![]() ![]() ![]() |
It locks around the top of the brake pedal. The Puma's is different (has that bulky switch box).
BuckBlu110 Member Since: 19 Apr 2014 Location: in the pub Posts: 732 ![]() ![]() ![]() |
I believe it’s the lump in the lower dash where the brake light switch it located, is why it won’t fit. The catch that locks the pedal lock, locks to the top of the brake pedal, so on pumas, this part of the dash is in the way. When they came out, The chap at x-eng was grilled on why they hadn’t made one for the puma and his response was that they tried numerous different designs but none were up to scratch and had more weaknesses than the one for the tdi/td5 lock, so was deemed no worth it.
Ok, interesting to know that they tried to do it, and I guess it’s probably not worth me trying, though part of me still thinks that even a modified xdefend with a few gaps and the lock in a different place would be possible, and maybe be more secure than one of the removable ones. Don’t want to spend £170 finding out though.
Mother superior Member Since: 05 Aug 2013 Location: Surrey Posts: 506 ![]() ![]() |
Gents
I got mine to fit by cutting 70? mm out of it and extending one of the cutouts a bit and then getting it stuck back together so it can be done. If you or someone tame is good with stainless you should be good to go. Let me know if you want some photos with dimensions Wes Oh woe, oh woe My crusty old landrover, It will not go. |
Daisy90 Member Since: 01 Feb 2015 Location: Hampshire Posts: 845 ![]() ![]() ![]() |
I always used cardboard or thin plywood for trying to make all the things that aren’t makeable
![]() Cheaper and easier n quicker to practice with ![]() I would imagine if Simon at X eng can’t / isn’t happy with a design there’s probably a reason, But they say you can’t re invent. A wheel ? But you cann make a nicer faster lighter different looking one ![]() |
Pictures would be great please Mother Superior - am definitely up for trying the mod.
I’ll get some photos up as soon as I can. I’m guessing that yes the mods I’ve done have compromised the design a bit but I took the view that it was another layer of security. If they really want the car then they’ll get it, not matter what you do, it’s been known around here for cars to be taken away by a hiab truck....
That would be great.
Agree - we’re basically just trying to discourage, delay and generally inconvenience thieves as much as we can. Having said that, there are advantages to some of the Defender’s security weaknesses, like when I locked the keys inside (my locks are all manual) while visiting family, and was able to borrow a torx driver and pop a door off within moments. |
