Home > Puma (Tdci) > New axle or repair the original
Page 2 of 3 <123>
You could always get a Britpart HD front casing....
https://www.britpart.com/all-parts/da1708
https://www.johncraddockltd.co.uk/land-rov...rt-xd.html
Bit spendy though..... better off getting a TUL XD military one as Blackwolf says, Or get yourself a decent straight used axle and weld on this strengthening kit:
https://www.tomcatwebshop.co.uk/axle-strengthening-kits-900-p.asp
Post #796171 1st Oct 2019 12:36pm
HardCharger
Potential problem with that solution for some is that it's a Britpart? Whistle
Anyone else make reinforced, aftermarket axles?
Anything we can add to stock axles to make them tougher?
Post #796288 2nd Oct 2019 8:06am
The only two failure modes of the late front axle case I have come across are the common (and terrifying) failure of the end flange welds, and the much rarer linear failure of (or adjacent to) the weld along the front of the long-side tube.
The former suggests to me an inadequate welding process with insufficient penetration, or possibly a metalurgical problem resulting in local embrittlement. The latter failure I would suspect is metalurgical exacerbated by the bending of the axle case in use.
I would think therefore that reinforcing the end flange welds and fitting a (military-style) gusset or brace under the axle would pretty well eliminate either failure in all but the most exceptional use.
If I found that my axle case needed renewing and I couldn't find, or chose not use, a military axle, I think that the actions I would take would be to find the most recent (i.e., least corroded) standard axle case I could get, grind out the end flange welds and reweld properly, then sleeve the welds and gusset the flanges, and then weld a gusset under the full width of the axle tube. I would probably reinforce the radius arm brackets as well. I think this would result in an axle case that was fairly indestructible but not excessively heavy.
Another option would be to cut out completely the tubular portions of the axle case and replace them with heavier gauge, possibly CDS, tube, but this would require much more complex and careful jigging.
The Britpart axle case is probably fine, but to my eyes it is a hideous fabricated thing which looks as though it was built by an Appalachian banjo player (with no offence intended to any members who live in Appalachia and play the banjo). I wonder also how much oil it requires compared to a normal axle.
Post #796294 2nd Oct 2019 8:27am
Yes the last link I posted above is a weld on strengthening kit
Post #796301 2nd Oct 2019 8:56am
HardCharger
Those were weld ons? OK, will go through the stuff again then. Thanks! Thumbs Up
Post #796312 2nd Oct 2019 9:43am
BogMonster
Falkland Islands 2015 Defender 110 Puma 2.2 USW Corris Grey
blackwolf wrote:
^^^ Take a look at these threads, they'll tell you all about the fault, Landrover's pathetic response, and you'll find the brackets pictured on page 6 of the first link.
Part numbers for the brackets are LR068818 (for the LH bracket), LR06882 (for the RH bracket).
They don't reinforce the axle or stop it failing, but they do (probably) stop you dying in a blazing fireball when the axle fails.
https://www.defender2.net/forum/topic33029.html (See page 6 for pictures of the brackets)
https://www.defender2.net/forum/topic55655.html
The most disturbing thing about both threads is that most of the failures discussed in them have occurred on vehicles which are outside the VIN range specified in the recall, clear evidence that this is a much bigger problem that JLR acknowledges. Personally I would not drive a TDCi of any age or any wheelbase without the catch brackets fitted.
Fascinating, thanks. I've never heard of any such thing happening here, and a great many Defenders here spend a lot of their time on very rough gravel roads bashing through deep potholes, so take a much harder hammering underneath than most UK vehicles. My own Puma is quite low mileage. I must ask around and see if anybody's come across it on older vehicles.
The 'modification' looks like a complete bodge up! The issues people have had here are with non-genuine swivel housings snapping off. Somebody I know once lost both front wheels at the same time (fortunately off road). In fact a family member lost a front wheel off his Prado this morning (more non gen parts) so wheels falling off is a subject I'm quite interested in at the moment! ---
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi
Post #796462 3rd Oct 2019 12:53am
MikeJ
United Kingdom 2013 Defender 130 Puma 2.2 HCPU Fuji White
I had the second failure over 2 years ago:
https://www.defender2.net/forum/post641259.html
We chose to weld it up and it's been fine since. That vehicle is a very heavy 130. It has a cherry picker on the back and weighs the full 3.5 tonnes.
Mike
Post #796541 3rd Oct 2019 1:15pm
Bluericky
United Kingdom 2009 Defender 110 Puma 2.4 DCPU Keswick Green
Still looking for a replacement diff but have got the old one out.
Here’s a pic with a couple of lines to show how bent it is . I’ve taken the mid point of the diff housing to the centre of the spring plate.
A bit heath Robinson I know but isn’t obvious in a pic !
 https://www.instagram.com/hustynminepark/
Post #796550 3rd Oct 2019 3:02pm
Mike
Mike, it was your failure that I had in mind when I wrote my post. A rare but disturbing failure.
Post #796551 3rd Oct 2019 3:13pm
Wow, that is not the way I was expecting it to be bent.
Post #796552 3rd Oct 2019 3:14pm
Bluest
That’s quite surpring. Wasn’t expecting it to be bent that way. How on earth did that happen? 2007 110 TDCi Station Wagon XS
Post #796553 3rd Oct 2019 3:22pm
Bluericky
Bluest , I have absolutely no idea how it happened .
There’s not a mark on the axle casing to suggest it’s been bashed .
It is however a second hand axle casing and replaced my last axle case that sheered on the weld so I’m assuming the replacement was already bent !
A bit strange that I had no problem putting the half shafts in when I did the swap over though .
Having spoken to our local Defender specialist today whilst trying to source a decent casing , he mentioned that he’d seen this a few times before on farmers vehicles and only Pumas. So obviously not a first ! https://www.instagram.com/hustynminepark/
Post #796559 3rd Oct 2019 5:01pm
Bluest
It's almost like someone has done an aggressive snatch recovery with the rope round the axle. 2007 110 TDCi Station Wagon XS
Post #796561 3rd Oct 2019 5:08pm
Bluericky
Ive just come across KAM axles , manufactured predominantly for the armoured defender market !
This may be overkill but it’s hugely tempting .
https://www.totaloffroad.co.uk/equipment/t...ter-axles/ https://www.instagram.com/hustynminepark/
Post #796823 5th Oct 2019 6:53pm
Looks hugely expensive, too Laughing Darren
Post #796828 5th Oct 2019 7:09pm
Page 2 of 3 <123>
