![]() | Home > Maintenance & Modifications > Centre dash light bleeding though |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20942 ![]() ![]() |
![]() Click image to enlarge ![]() Click image to enlarge ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4807 ![]() ![]() ![]() |
It’s the same on mine Steve, drives me nuts
![]() 2008 SVX 90 2000 XS TD5 90 |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 ![]() ![]() ![]() |
Looks good
I have light bleeding from the hot & cold knob ![]() My new HD unit dims when I use the lights which is good |
I did suspect I may not be the only one hence mentioning it.
I’m happy with the result, just that annoying little issue. I have some of these LED chips left over if anyone wants a set? I haven’t counted how many I have left but I think there are at least a set or two left. If anyone wants some let me know FOC. I have a few more pics somewhere. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
This was the clock repair. Not an LED, I don’t have any more of these but RDX do them. About £6 vs LR wanting you to buy a new clock! @ £60 approx when it was just a blown bulb.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
This is the LED chips. I have one set 4x spare.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Out with the old, in with the new: ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Steve are these a straight swap or do they require soldering etc? If they are a straight swap may I have them please? 2015 HT XS 90
Simon - Yep, course you can. Straight swap. Just be sure to check polarity is correct orientation and they are working before putting the dash back in.Pop me your address by ‘PM’ and I can stick them in the post for you. 👍🏻 ____\We|Will|Win/___
LR110 BG Member Since: 02 Apr 2019 Location: Wiltshire Posts: 16 ![]() ![]() ![]() |
Hi Steve,
I don’t suppose you ha s part number or where you ordered them from? As I need a new clock bulb. |
For the dash bulb RDX via eBay.
It is an incandescent bulb with green cover, I don't think there is any LED solution. LR don't sell any spare bulbs or parts only the clock its self for over £60 a piece. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Bulbs arrived today
![]() Will let you know if the blacktac fix works ![]() 2008 SVX 90 2000 XS TD5 90 |
Fitted today and wow much brighter thanks Steve. I put a little sausage shaped piece of blacktac along the area you were having the light bleed from as I was too and this has worked to prevent the bleed and the functions all work correctly too on the heater sliders
![]() ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
