Home > Maintenance & Modifications > X Eng hand brake....worth it?
bear100
I’m having trouble with my hand brake, it won’t go to it’s final position and lifts slightly causing the brake light to come on plus i can feel the brake holding slightly and the lever comes up too far.
So I was thinking of investigating or upgrading
The X Brake by X Eng seem to be a favourable choice, has anyone got one and what do you think?
Is it worth the money or not much difference to the standard brake
Is it a diy on the drive fit also?
Lots of questions Shocked 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #795719 29th Sep 2019 8:46am
donmacn
Well worth it, in my opinion.
I fitted one of these, must be 10 or 15 years ago. That's a real 'guess-timate' as I don't know when they came on the market, but a long time.
I think there was a slight rattling noise when first fitted - perhaps a common issue - but a blob of silicon somewhere (can't remember) fixed that and it hasn't given me a moment's trouble ever since.
I plan to fit a new propshaft soon-ish, and I've thought that I might take the brake off and give it a service, but genuinely it's been on for ages and been great.
I went for it because my drum brake was 'catching' in neutral while coasting up to traffic lights, therefore probably catching all the time, just wouldn't notice. There is a thread here where someone said that it was better just to properly adjust the original, and maybe get the drum re-machined. Not arguing with that really, but for me this was a good mod.
I can't really see a downside apart from cost maybe.
DIY fit? Yep - but on a dry day so your not lying in the wet! Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #795738 29th Sep 2019 10:00am
Grenadier
Looks like a good bit of kit.
Ball, another upgrade to the list... Big Cry Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #795753 29th Sep 2019 10:57am
bear100
Grenadier i think they are fitted to all the challenge trucks, Steve who engineers the x eng stuff claims it will hold with any load or weight as long as you have traction Shocked
donmacn i presume you fitted yours to a tdi? i can't seem to find anything on them fitting the puma though 2023 Defender L663 V8
Post #795794 29th Sep 2019 1:50pm
Mdm
a well maintained and adjusted std handbrake is fine for almost all lr owners i reckon.
we had the x brake on the challenge motor for ease of use and zero maintenance. no issues with mud build up and very effective.
i would get yours fixed as it will be cheaper in the long run
Post #795798 29th Sep 2019 2:14pm
donmacn
Bear - yes, you're right, mine is on a 300TDi, but I've just checked the Foundry 4x4 site (understand they have the X-Eng brand now?) and found this page:
https://foundry4x4.co.uk/index.php?route=p...duct_id=56
This says that as long as your vehicle has the LT230 transfer box the brake will fit, though you may need a different cable.
As I say, not really wanting to argue against the standard set up, perhaps I didn't take the time to get to know its foibles well enough. However I certainly feel as if my X-eng one has stood the test of time. I can't remember in the slightest what it might have cost, but that's almost neglibile when divided by the years, and an easier solution. Again, in my opinion. Donald
in the past..
Post #795801 29th Sep 2019 2:46pm
oneten110
Been using the standard set up for 25 years with no problems whatsoever. It has held a fully loaded truck and GKN Rapier trailer on gradients. It is not a Defender, it is a One_Ten
Post #795840 29th Sep 2019 6:55pm
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
I've got one to fit as I've had issues with the std one time and time again. I've had it go out of round, then it fell off when I broke the prop and was driving home in fwd (my fault). Bought a replacement, to then get a oil leak and had to change the shoes again.
I've also had issues with it clogging. 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #795851 29th Sep 2019 7:16pm
dioliahary
Mine has been reliable, I only changed to one years ago cause I could but have been happy with it. 1990 200tdi conversion 90
Post #795868 29th Sep 2019 7:57pm
bear100
Thanks for the reply’s Thumbs Up
I think I will go for the X brake, I get a lot of heat from under the cubby box and around the hand brake which I’m sure it’s down to the drum
Thanks all Thumbs Up 2023 Defender L663 V8
Post #795888 29th Sep 2019 8:54pm
foxhound
United Kingdom 1995 Defender 110 300 Tdi SW Alpine White
i thoroughly recommend my X Eng handbrake. my bogstandard handbrake couldn't hold my 110 and sankey trailer on a steep metalled lane at home in Devon years ago, and I've not had any worries since fitting the X Eng. 110 Defender 300tdi & Penman trailer with ally exped top and roof tent
Post #798928 21st Oct 2019 2:00pm
jst
i ran some of the prototypes for Simon when the idea was first born and many moons prior to Foundry taking on the X-Eng brand. i love them and have them on my off roaders. but for mainly road going vehicles i stick with the std setup which when set up correctly works well in my experience. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #798930 21st Oct 2019 2:18pm
But I'm betting that was a standard handbrake is a state of disrepair rather than a perfectly clean and setup one?
Nothing wrong with swapping to the X eng disc for various reasons but it doesn't solve an issue that isn't there.
Post #798943 21st Oct 2019 4:24pm
