shropshiredefender wrote:If I remember correctly the Salisbury rear axle has 24 spline half shafts, the Rover rear axle is 10 spline.
More recent axles are all 24 spline (from 300tdi days, IIRC) but I don't know if the half shafts are the same length for the Salisbury axle. Darren
28th Sep 2019 8:43pm |
sako243
Danny Fireblade wrote:Is it difficult to get them welded or would anyone who is semi competent be able to achieve this?
The main thing is that the metal will almost certainly be heat treated to provide it's mechanical properties. Any welding will need to bear this in mind and possibly be redone as simply welding it will make the material softer again. Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
28th Sep 2019 9:11pm |
