Home > Maintenance & Modifications > Which 1 piece drive shaft/flange?
Danny Fireblade
United Kingdom 1998 Defender 110 300 Tdi HT Alpine White
I have a 97 300tdi with a salisbury rear axle and I am looking to fit the 1 piece shafts/flanges.
Has anyone fitted the same and if so where did you purchase from etc? Has fitting them solved the clunking and backlash issue? Did they come with replacement bolts/gaskets?
I have tried the search function but having trouble finding a definitive answer.
Thanks
Post #795489 27th Sep 2019 7:43pm
You may have made up your mind already but I can't fault Ashcroft HD 2 piece. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #795519 27th Sep 2019 9:09pm
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
I had mine welded by a certificated welder around 25k miles ago
Together with an Ashcroft output shaft I now have almost no backlash. Just because you're offended doesn't mean you're right.
Post #795524 27th Sep 2019 9:36pm
Zed
Steve, did you paint the drive flange?
I'm thinking of getting the same but want it black and I'm undecided on what to use.
Post #795525 27th Sep 2019 9:38pm
I didn’t no as I am using boosts I didn’t see any point really and needed parts on ASAP.
Another member here did recently I believe as I saw the pics.
Only a key, mask off the threads.
Etch prime and satin black would be fine and pretty quick too.
In my situation I’m quite happy as they are.
If you had ZU’s or similar on display then yes I would want to paint them to match. Possibly even 2 pack paint match. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #795528 27th Sep 2019 10:49pm
Zed
Cheers Steve, I knew I'd seen somebody on here paint them but wasn't sure who.
Not sure whether to paint or use a product like Por15, Buzzw etc.
Post #795530 27th Sep 2019 11:06pm
Could have been mine a week or so ago?
A couple of coats each of etch primer, regular primer and satin top coat. Darren
Post #795535 28th Sep 2019 12:15am
Zed
Bingo! Nice one Darren.
Looks great.
Post #795550 28th Sep 2019 6:35am
Danny Fireblade
I am not too keen on the 2 piece ones tbh and I would prefer to buy new ones rather than welding my ones.
Would these fit doesn't anyone know?
https://www.steveparkers.com/product/lr072...r-axle-rh/
I am struggling to find the correct ones if they are not right?
Post #795595 28th Sep 2019 1:26pm
Are Salisbury ones different to regular ones? If so, I don't know if they actually exist Confused Darren
Post #795603 28th Sep 2019 1:54pm
Danny Fireblade
I have no idea if they are different or not?
It would be so much easier oft hey were the same?
Post #795604 28th Sep 2019 1:57pm
shropshiredefender
If I remember correctly the Salisbury rear axle has 24 spline half shafts, the Rover rear axle is 10 spline.
The only way that I could find to fit one piece half shafts to my old 300tdi 110 (roughly 20 years ago) was to have them welded.
I ran it for 200k miles like that with no problems.
The current Puma was treated to the same mod (with new parts) when the backlash became bad. Just because you're offended doesn't mean you're right.
Post #795606 28th Sep 2019 2:42pm
Danny Fireblade
Is it difficult to get them welded or would anyone who is semi competent be able to achieve this?
I am thinking I may have to get replacement 2 piece ones and get the old ones welded for when the replacements get sloppy?
Post #795608 28th Sep 2019 3:04pm
shropshiredefender
For a proper job you need a skilled welder with the correct kit try to find a blacksmith or fabrication shop.
Anyone who is a semi competent welder (like me) can do a "bush fix" to get you home. Just because you're offended doesn't mean you're right.
Post #795620 28th Sep 2019 4:00pm
Or buy HD flanges, which don't get sloppy in the way that the OE ones do. Darren
Post #795678 28th Sep 2019 8:41pm
