![]() | Home > In Car Electronics > Extra 12v socket installation issue |
The obvious thought is that the wires are reversed. You'd still get 12v but the sat nav probably needs the polarity to be correct. Darren
ginjez Member Since: 18 Sep 2011 Location: huddersfield Posts: 1777 ![]() ![]() |
Hi Darren, polariity is correct according to volt meter.
Dunno then. Duff socket contacts, maybe? Darren
Lefty loosey Member Since: 10 Sep 2019 Location: Bridgend Posts: 2 ![]() ![]() ![]() |
Bad connection somewhere when the circuit is under load the voltage drops. I know the satnav will only be a small load but might drop it enough to not power the satnav and only the led.
I'll check earth tomorrow.
Welcome to forum btw ![]() |
Pilgrimmick Member Since: 16 Nov 2015 Location: Highlands Posts: 582 ![]() ![]() |
12.7v is that with the engine running? If so it is low, wants to be about 14v 80" 1948
Lightweight V8 Bowler Tomcat 130 Station wagon 90 300tdi (Santana PS10 pick up) Range Rover L322 (Ful fat) |
Checked tonight and you are correct ![]() |
