Home > Technical > Heated screen wiring
Bps
Hi all after some advice in heated screen wiring please.
I have a 3 tag screen one central and one on the left and right. Am I right I’m presuming the central one is the earth and left and right power for that side of the screen respectively? Should I power them separately or together, use a timed relay etc ? It’s in a military 110 so the wiring kits with original switches are not really suitable for my dash.
Any input would be greatly appreciated
Bps
Post #795026 25th Sep 2019 12:32pm
ickle
I think mine is central power and two earths IIRC, earthed at the windscreen block bolts
Also because of the inherent design and heavily tinted rear windows with night time reflection I don't use the rear window much, don't have an interior mirror and use the rear camera if required, so I disconnected the feed to the heated rear window at the grey bulkhead multiplug and used the standard HRW circuit to power the windscreen - no timer but quick and easy and totally reversible.
HTH Keith
Post #795051 25th Sep 2019 3:12pm
dorsetsmith
Post #795052 25th Sep 2019 3:24pm
Bps
Thanks everyone, good reading. Soft top so no rear heated window 😂
Post #795064 25th Sep 2019 4:28pm
MYSTERY
may be of use
Post #797849 12th Oct 2019 3:11pm
