Home > Puma (Tdci) > PUMA Electrical Problems after some rear Chassis welding...
RobM
Australia 2010 Defender 110 Puma 2.4 SW Chawton White
Guys, Posting this on behalf of a mate...
He had some welding done at the rear of his Defender 130 (2.4ltr Tdci) in regards to some mods to his sway bar setup. The person doing the welding "did" disconnect the "main" battery but wasn't told of the "aux" battery and therefore left it in circuit but it is only used for powering his aux fridges, etc so, in theory it shouldn't have mattered...
Upon picking up the his 130 and heading back home the vehicle started doing the following:
> Speedo above 40kms/hr started behaving erratically increasing up 18kms/hr above current speed w/o reason (Tacho did not vary at all)
> Handbrake Dash light started flickering on/off
> Vehicle Engine sometimes surging erratically above 40kms/hr - like when the VCV starts playing up, but he had his replaced 2mths previously
Bit of History: The mate did refuel prior to driving the distance to the final destination & it performed faultlessly. Vehicle was performing as per normal before the welding was done... Fuel Filter Checked/cleared OK
Ideas/suggestions from anyone would be appreciated...
Current diagnosis from mechanics is possible damage to both the Engine ECU and Dash Instrument ECU which will be very expensive if this is the cause...
Will using a 2nd hand ECU from a Ford Transit be an option?
thanks in advance.... Cheers.....
Rob
1995 Defender Tdi 110Wgn
2010 Defender PUMA 110Wgn
TRIPS: Meanderingdownunder WikiLoc Trips
Post #794811 24th Sep 2019 9:19am
Martin
Site Admin
The speedo flickering and power surging may be related.
The instrument pack is directly driven with a speed signal from the speedo transducer, the instrument pack puts the speed out as CAN messages for the engine ECU to use.
If the input signal to the instrument pack is faulty, the CAN messages the ECU is reading will be faulty.
I would look at the speedo transducer on the rear output housing of the transfer box, swap with a known good one.
The handbrake light flickering could also be a low brake fluid level (check this first - and if low then find out why - did welder damage a line/hose?).
Otherwise check the handbrake switch and loom for damage/chafing of the wire.
Another thought - as the handbrake switch and speedo sensor are in roughly the same place - check around that location for damage/rubbing/chafing of the loom - just in case.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #794819 24th Sep 2019 10:06am
RobM
Thanks Martin...
I'll pass that onto him to check it out
rob Cheers.....
Rob
Post #794822 24th Sep 2019 11:41am
RobM
Also, I forgot to mention as well that there was no fault codes up when the mechanic put his diagnostic tool on...
So, would a faulty speed sensor give up any fault codes?
Rob Cheers.....
Rob
Post #794823 24th Sep 2019 12:00pm
Martin
Site Admin
It may be sending erratic signals but the instrument pack is just displaying the result of those signals. It might do a open/short circuit test but otherwise there may not be other diagnostics available.
The lack of fault codes is in some respects a good sign, but then it's down to old-fashioned head scratching Wink  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #794824 24th Sep 2019 12:12pm
RobM
Hey Martin...
Just want to say THANKS AGAIN.... it looks like u were again right on the money.... much appreciated
Past on your info to him and yes it looks like the handbrake like was low fluid plus the mechanics have now ordered a new speed transducer as the possible fault.
Will keep u posted Wink Cheers.....
Rob
Post #794965 25th Sep 2019 2:14am
RobM
Looks like I may have spoken too soon... Just heard back from the mate and he said the mechanics replaced the speed transducer and the problem is still there. Next thing they are looking at is the Instrument ECU... Cheers.....
Rob
Post #794966 25th Sep 2019 4:40am
Martin
Site Admin
That's a shame Sad  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #794991 25th Sep 2019 9:22am
RobM
Martin,
You weren't too far off... the mate just told me that the mechanics found the plastic gears within the Transfer Case that are used by the transducer to measure your speed - apparently the plastic gears were partially stripped.
The mechanic removed the backing of the Transfer Case to access these plastic gears and replaced them and all is NOW GOOD according to the mate, so in the end not as bad as it was looking, just mainly labour costs to track down problem...
Curious... These plastic gears - if they totally fail totally I wonder what happens to the drivability of the car? Would u still be able to drive it or not?? Cheers.....
Rob
Post #794994 25th Sep 2019 9:41am
RobM
Martin,
Rob
Post #794995 25th Sep 2019 9:41am
Martin
Site Admin
At least he's not had to throw a load of money at a new ECU or instrument pack Thumbs Up
If you lose the vehicle speed sensor/gear then the engine ECU doesn't know the road speed and can't work out the gear.
It disables the torque smoothing between gears and makes the drivetrain clunky, but it's still possible to drive.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #794996 25th Sep 2019 9:44am
RobM
Good to know.... especially when in the middle of no where... Cheers.....
Rob
Post #794998 25th Sep 2019 9:49am
