![]() | Home > Puma (Tdci) > connector subwoofer |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6681 ![]() ![]() ![]() |
There's no separate loom available for the subwoofer end, only bits of adapter harnesses at the radio end.
I can supply a plug and pins for £7 plus £3 UK post (it's lumpy) - I've done a retrofit on my 2014 90 XS by building a custom retrofit loom. ![]() ![]() |
P055um Member Since: 12 Mar 2017 Location: Shropshire Posts: 6 ![]() ![]() ![]() |
Hi - I had the same problem. Called Alpine and explained the situation and they have a wiring kit for the standard SWE1200 which will work with the special version developed for the Puma. It is not cheap (about £30 from memory) and I believe that the part number is PA015000A034.
![]() Click image to enlarge You will need to remove the amp from the unit and remove the lead to the power supply and replace with the Alpine wiring kit. This will give you all the connections for the head unit. Used it on my retrofit and it works fine. Hope this helps. |
Just checked - the part number for the power cord is 01E44813S01. Price was £36 inc shipping etc. There is a guy on ebay selling one for slightly more.
Should have mentioned that the RCA connectors are fairly short and I purchased a 3m extension (male to male fittings) to link up to the head unit. However, getting the plug and pins from Martin would be a much cheaper option! |
Matt110 Member Since: 29 Jun 2014 Location: UK Posts: 687 ![]() ![]() |
In the OE install where do the RCA cables route?
mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2947 ![]() ![]() |
Is there much difference between the LR one and the SWE1200? Been trying to find a used factory one for ages now. One on ebay at the minute but looks like its been kicked down the road! Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
The LR one has the amp integrated and therefore is a bit deeper than SWE which comes with it separately. Also, the Alpine logo is upside down if fitting on the back of the cubby box.
can it not just be fitted the other way round?
![]() 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
I am sure that it would work just fine. It is just that the speaker aperture would be facing upwards. Otherwise no problem. Or just live with the logo upside down...
