Home > Maintenance & Modifications > Britpart extended wheel arches
kzycnn
United Kingdom 2003 Defender 110 Td5 XS CSW Oslo Blue
Hi
I'm running with 30mm spacers and 265 tyres. As a result I get a lot of muck spraying up the side of my car. Can't fit the Dirt D-fender that MUD supply as I have tree sliders fitted.
I've seen these beasties from Britpart...
https://www.britpart.com/parts/exterior-pr...its/da1978
Anyone have any experience of them? I'm tempted as they look OEM, should have the same OEM flexibility and, at 30mm wider than OEM, should put me back to where I was (muck wise Smile ) before adding the spacers.
There seem to be loads of different prices out there as well so I'm a bit uncertain as to what would actually be supplied. For example, Britpart supply as front/rear pairs at (about) £92 but I found these as well
https://www.lrparts.net/lrc1418-set-of-fou...-pair.html
That seems sensible as a full set but why is cutting needed? I assumed you'd just unclip the originals and clip in the replacements?
Confused, as seems to be the norm these days Confused
Tony
Post #793992 19th Sep 2019 2:03pm
dantastic
The reason you need to cut is in the installation instructions
https://www.lrparts.net/mwdownloads/download/link/id/3/
That's a bit Censored . Would it have hurt them so much just to make a complete arch.... Censored !
Post #794006 19th Sep 2019 4:52pm
I fitted some to the v8, yes you have to cut the fronts, so try buy some crappers off ebay and keep the originals.
I quickly hated the look and reverted back to standard. QRZ 2e0vpf
Post #794032 19th Sep 2019 7:08pm
Have you considered the Gwyn Lewis mud flap extenders? They push the flaps further outboard to solve exactly this problem. Darren
Post #794085 19th Sep 2019 9:25pm
Rad666
United Kingdom 1998 Defender 110 300 Tdi DCPU Keswick Green
I like em, inner arch needs cutting out, also have the gwyn lewis mudflap brackets
Post #794127 19th Sep 2019 10:41pm
I was really unsure, Mrs G said she preferred original, so I switched back. QRZ 2e0vpf
Post #794142 20th Sep 2019 7:42am
Oops, that’s before.
After.
 QRZ 2e0vpf
Post #794143 20th Sep 2019 7:44am
dantastic
I agree, looks better with the standard ones!
I have the gwyn lewis mud flap extenders mentioned. They are brilliant, no muck on the sides with sticky outey tyres.
Post #794148 20th Sep 2019 8:34am
kzycnn
Thanks for the replies. I'll have a bash at the mud flap extenders and see how it goes. Not sure about the Britpart arches from the pics.
Tony
Post #794170 20th Sep 2019 1:12pm
