![]() | Home > Technical > 90 Puma rear brakes |
| stuart123 Member Since: 03 Apr 2017 Location: Manchester Posts: 207
Anybody?!
| Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 737
There is a pressure sensor for the rear brakes which may have seized. See link below:
http://slroc2.co.uk/forum/index.php?topic=4336.0 Mine has never been tested on a rolling road so don't have values to compare. Hope the link works. |
Thanks, I had read that forum but couldn't see where a pressure sensor is actually fitted?
I am not certain where it is . I only have access to a 2012 workshop manual which states:
On 90 models a pressure reducing valve (PRV), fitted to the right-hand bulkhead in the engine compartment, maintains the braking balance. Pressure to the rear calipers is regulated by the PRV, this valve is of the failure by-pass type, allowing full system pressure to the rear brake calipers in the event of a front (secondary) circuit failure. Hope this helps. |
| derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 568
If ABS is fitted it will not have a PRV. Did they lock on the rollers when these pressures where achieved? If so try loading the rear to max weight and try again.
Readings don’t sound too bad, and you don’t want the rear ‘stepping out’ in an emergency braking situation. Cheers Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
| keef9t Member Since: 13 Mar 2016 Location: manchester Posts: 186
I posted on this problem back in 2017. I would suggest all 90's without ABS will give similar rolling road readings. The result of the PRV doing it's job in preventing dangerous rear wheel lock-up. The 110's don't have one fitted.
I have used the same garage with the same tester for years and he always said " all 90 rear brakes are crap, the 110's ok" I told him about the PRV and he now understands. He uses the Tapley footwell meter on mine since we came to an understanding and it passes. The vehicle would fail the MOT based on the rolling road figures. If you suggest to your tester that the rolling road could potentially damage the transmission they should be minded to use the Tapley footwell meter. Just out of interest, I had renewed every part of my braking system, except the steel pipes ( I'm talking Master cylinder, servo,PRV, flexibles, discs, callipers, pads and fluid). It made absolutely no difference to the readings. For once, "they all do that,Sir" has ring of truth about it Life is short, so have your pudding first --------------------------------------------- 2007 90 2.4Tdci County HT Stornaway Discovery 1 200Tdi Sold 90 Turbo Diesel HT Sold 110 2.5NA CSW Stolen 88 Series II Sold Meccano Set. Don't know what happened to that |
Interesting, thanks. No ABS fitted. Not sure about locking the back rollers... |
Thanks for that. It passed the MOT using the Tapley brake test. It was only me asking them to put it on a rolling road to see what the rear brakes were actually doing after the fronts kept locking up. Maybe I need to look at changing tyres.... |
The pressures are in balance both front and rear.
With no ABS you will inevitably lock up the axle with the greatest pressure if you brake hard. That's why we were taught cadence braking in the old days before ABS! As stuart 123 says, designed to lock the fronts before the rears and if he has similar readings, then probably all ok. Tyre condition will also have a big impact on braking - old tyres become hard and loose their grip more easily. |
| All times are GMT |
