![]() | Home > Td5 > Identifying wires - Purple/Brown |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2358 ![]() ![]() ![]() |
Your vehicle is 2002 110 Td5 SW right?
Think it's the C0287 connector https://www.lrworkshop.com/connectors/defender-2002my/C0287 Better ID's here https://www.lrworkshop.com/connectors/defender-1999/C0287 > 110 XS Double Cab |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6698 ![]() ![]() ![]() |
They are a permanent feed to:
Radio Speedo (2 feeds) Diagnostic socket Interior lamp From fuse 30 [5A] in the satellite (seat box) fuse box The blue header splits a single incoming feed multiple ways. ![]() ![]() |
steve_c3 Member Since: 30 Apr 2015 Location: Hants Posts: 179 ![]() ![]() ![]() |
Thanks Martin and Hank, much appreciated. I needed to know as after 2mins driving this morning, I had smoke coming from behind the radio and also from hole at the bottom of the OS B pillar and from the roof lining at the driver door (although this last one may have traveled up the pillar so originated from lower down).
Fortunately I stopped in time and disconnected the battery and the smoke stopped. Now I just need to trace the cause. Two of the purple and brown wires to/from the blue block have melted. The internal lights did stop working which ties up with Martins messsage. Looking in the satellite fuse box there is also a melted 15A fuse. ![]() |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
Check for rub through on the interior light wiring up the screen pillar and to the roof. You have a short somewhere.
