![]() | Home > Off Topic > Solidworks computer |
| rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2243
What version of Solidworks are you looking to run? I am assuming the latest 2019 revision?
Have a look here at the system requirements for a start: https://www.solidworks.com/sw/support/SystemRequirements.html Cheers, Steve 02' 110 TD5 Double Cab Rebuild Thread |
| NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681
Yeah Steve 2019
If you arnt doing anything too fancy then a Windows 10 machine with a reasonable processor and 16Gb of RAM would be fine. Make sure you get a machine with a graphics card that is supported by Solidworks though.
I would personally go for a Desktop machine as you will probably want to use it with a bigger screen, keyboard and mouse; in which case a laptop will be a bit pointless. Cheers, Steve 02' 110 TD5 Double Cab Rebuild Thread |
Thanks Steve, what are you running it on?
I don't use Solidworks very often, i use Autodesk inventor most of the time now (as work dictates). Both bits of software have similar hardware requirements though.
I my work laptop is a Core I7 with 32Gb RAM with Windows 10. Its an Nvidea graphics chip but dont know what it is. It does get very hot when doing large assemblies or rendering though (hence why i would recommend a desktop instead) 02' 110 TD5 Double Cab Rebuild Thread |
| OsloBlue Member Since: 14 Jul 2018 Location: Essex Posts: 825
Hey Nick you won't need just RAM for solidworks.
More importantly you will need VRAM (video memory) I used to have a two draughtsmen under me and had to get them setup so they could have solidworks. We had Two 32GB RAM, I7 processor and 4GB of VRAM, with SSDs for a reasonable setup. they were about £1400 computers, without even starting of solidworks, autocad, trimble, office, monitors, mice, keyboards ect... more importantly why do you need £3K worth of cad software and can you even use it? can you justify using it? will autocad suffice? I'm on IG: https://www.instagram.com/osloblue42/ Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html ![]() |
I disagree slightly with that Oslo. I have run it on much lower spec graphics cards and find that it works fine as long as you dont ask too much of it and dont try and do any ray tracing or reflections or complex compound surfaces.
If the graphics performance is set to a lower quality a lower spec graphic card will suffice for simple modelling and assembly of mechanical systems. Steve 02' 110 TD5 Double Cab Rebuild Thread |
then the problem you have is overheating or overclocking which causes wear and tear on systems.
We tried pushing a 500mb ram, celeron & integrated graphics onto trimble and the thing degraded quicker. how many polys do your typical models contain? I'm on IG: https://www.instagram.com/osloblue42/ Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html ![]() |
500Mb is too low obviously but 1Gb or 2Gb should do the job.
I generally do isolated mechanical or structural items but currently working with large full facility models which push the limits or Inventor anyway (i find it very unstable with huge assemblies). These have a lot of surface details as the base model has come from 3D scan pointcloud. For very large models we generally use Catia anyway. Steve 02' 110 TD5 Double Cab Rebuild Thread |
What i'm getting at is that solidworks is a beast even when working on low poly stuff,
It was designed for integrating jet turbine physics and jet airframe physics with millimetre precision. What kind of assemblies are talking about here? are we talking about structures, parts, tools or machinery? I'm on IG: https://www.instagram.com/osloblue42/ Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html ![]() |
Back to school late in life so just starting out using it. That means I get the student version for nothing though, hopefully that makes a bit more sense.
| All times are GMT |
