![]() | Home > Tdi > Severe coolant leak problem |
tolley Member Since: 07 Nov 2011 Location: gloucester Posts: 1125 ![]() ![]() ![]() |
how much coolant was lost Jimmy ?
jimmythomson Member Since: 18 Jul 2017 Location: Norfolk, UK Posts: 46 ![]() ![]() |
I have to admit that I don't know. I guess I won't find out unless I fill her up again. Unless there's a way I can gauge how much had been lost?
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1887 ![]() ![]() |
There's another similar thread on the go just now.
On that one, it seems to be a burst pulley bearing on the water pump. ( https://www.defender2.net/forum/topic69040.html ) As I said on that thread, when this happened to my car (my wife was driving, not her fault in any way, but maybe she didn't stop as soon as I might have - steam escaping from under the bonnet ![]() ![]() I don't think there's going to be any way to figure out how much you've lost except to monitor how much it takes to refill the system. Check all the hoses/joins before doing anything. Looking for splits/loose connections or other obvious leaks. As in the thread above, the leak was obvious even without the engine running. I guess that would be the ideal situation - something obvious, and hopefully easily fixable. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
Quick update on this. I topped up with coolant and the symptoms are the same as JonJop's on the thread referenced by donmacn (thanks, btw). In other words, with the engine off, I top up and then get a steady stream of water coming from around the back of the power steering pump. I'm not sure that I can see how the water pump being defective would result in the water coming out there though. A mate suggested it could be a core plug, so I think I'll remove the fan tomorrow to get a look at the core plug at the front center of the block. If that looks okay then it's off with the water pump.
Any other/better suggestions welcome. ![]() |
could even be the P gasket
Had a closer look today and managed to spot coolant spurting out of the front core plug. I'm guessing that the ancillary casing needs to come off for this. Is that the case? Does anyone know the procedure? Nothing much in the Haynes manual, though I did find this from Britannica Restorations on YouTube:
However it doesn't look like he has a power steering pump on that one, so makes like a lot easier I suspect. Any advice much appreciated. |
have used this video and drill & side hammer method to remover core plug (dry fitted the new core plug ) |
Thanks, dorsetsmith. Successfully removed using some punches and a hammer. Replacement plug and p-gasket on order
Just to finish the story, and pass on a lesson...
I received my core plug and gasket, and set about finding something to knock the core plug in with. I wanted to find something that would be just fit in to the inside of the core plug so that I could knock it in straight and level. I found just the job in the way of a Nielsen bearing driver. About 15mm of solid aluminium. So away I go, hammering it in, nice and level, feeling pleased with myself..........until it came to removing the bearing driver! it was such a snug fit inside the core plug that the core plug had gripped it tightly as I banged it in. It wasn't going anywhere.. I could have cried. ![]() Anyway, after several hours of drilling the ![]() Rookie mistake perhaps, but lesson well learned. Jimmy. |
