![]() | Home > Wheels & Tyres > 16" tyre pressure variations |
Grouse Member Since: 16 Apr 2012 Location: on the hill Posts: 535 ![]() |
28 front and 35 rear - 110 with HD suspension and average load - if fully laden 48 rear
28 Front and 48 rear is std for MOD 110 |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2673 ![]() ![]() ![]() |
One of my long-time overlanding friends showed me the correct way determine your tyre pressures:
Every tyre has a max load, max pressure, and max speed rating. Load your car and weigh it on each axle. Then work out the pressure from there. You can then adjust as you need for different loads, etc. For gravel travel, drop by half, or 1,8 bar. For off-roading, drop to 1.4-1.6 bar. For sand, drop to 1.0 bar, 0.8 bar if very soft sand. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3746 ![]() ![]() ![]() |
I have a 90 HT puma, and unladen I go with 30psi all round. Seems comfortable enough to me and no traction issues.
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5986 ![]() ![]() |
32 all corners. If serious mud then drop to 12
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2268 ![]() ![]() ![]() |
And if towing around 48psi for the rear with fronts more 30's is fine??
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 786 ![]() ![]() ![]() |
I just follow the manual and the label on the door jamb, 30 psi front, 48 psi rear. I add 2 to 4 psi if I've been running for a while when checking the pressures.
One of my friends suggested that I lower the pressures a bit as the ride was, according to him, a bit on the bouncy side. This is when I ran the Cooper STMaxx that I got as new old stock so the rubber might have hardened already. When I recently switched to newly manufactured Pirelli Scorpion MTs, even with the 30 - 48 pressures, the ride is very civil. There are proponents to the 4 psi rule which involves a lot of measuring to determine pressures as they will work for you and your set up. But once you find out the appropriate pressures for you, it'll be pretty spot on to ensure longer wear intervals for your tires, a good ride, and optimal traction provided. Once I get better kit, I'll probably do this again as it did wonders for my H*L*x back in the day. |
