Home > Technical > Brakes - Type and brand
OsloBlue
United Kingdom 2003 Defender 110 Td5 XS CSW Oslo Blue
All, after having my car serviced and finding out i need a new ABS unit it also came to the attention of my guy that the rear brake pads were wrong.
Apparently they come in Two thicknesses and i require the thicker of the two but i have the thinner of the two, so i only have 1mm of working pad left before they're completely worn and have no contact.
Had a look at microcat and had a look about and can't find any reference to thicker pads? Anyone know which part no i should have?
Also what are the best brand to use? are there any performance pads out there? Wouldn't mid going premium just so long as they're not ablative type.
Cheers, I'm on IG: https://www.instagram.com/osloblue42/
Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html
Post #793018 14th Sep 2019 2:18pm
dorsetsmith
SFP000250
Rear brake pads - 110/130 - From 2A
disc diameter rear 110 - 130 298mm
disc thickness 14.1mm new
disc wear limit 110-130 1.0mm per side of disc
pad minimum thickness 3 mm
Disc run-out maximum 0.15mm
Post #793026 14th Sep 2019 3:24pm
Tommo
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
Yep...genuine!
Post #793119 15th Sep 2019 11:19am
OsloBlue
Thanks but doesn't answer my question on thicknesses,
Tommo bit of a problem being that LR used three separate brake pad suppliers Mintex, Ferodo and delphi,
Genuine LR is just a raffle as to which OEM brand they used. I'm on IG: https://www.instagram.com/osloblue42/
Post #793139 15th Sep 2019 1:51pm
rallysteve
You need the pads for 2A onwards: SFP000250
The thinner ones are for upto 2A which are: SFP000280
Delphi Lockheed everytime for me
Post #793140 15th Sep 2019 1:53pm
OsloBlue
fantastic cheers steve I'm on IG: https://www.instagram.com/osloblue42/
Post #793141 15th Sep 2019 1:58pm
