![]() | Home > My Defender > My Lucinda the TD5 110 (new to defender ownership) |
| OsloBlue Member Since: 14 Jul 2018 Location: Essex Posts: 825
Restoration
Replacement Bullbar mounts Bottle Jack Strip Carpets Affix Sound insulation Replacement Seats Replace carpets with exmoor or equiv, Replacement headlining Refurbish Boosts Replacement speakers Complete body respray in regional 644 Oslo Blue Checker plate resprayed or anodised black improvement: Dashcamera (better one) Roamerdrive overdrive. (probably before restoration) Rear window Guards Mechlock? Maybe? 2DIN/ single din 7 inch screed Audio Rollcage Improved suspension panoramic Rear windows HALO LED headlights LED Sidlights & indicators LED light Bar DRl bumper Aux lights to bullbar KBX Air scoops Puma Bonnet Replacement second row door cards Kick plates for door cards MOLLE rear door card system Modification Allisport intercooler improved turbo Remap Silicone hoses Dual feed airbox maybe? Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html ![]() |
| Adam17 Member Since: 15 May 2018 Location: Within Bedfordshire Posts: 1193
WOW
That's some list. And some good ideas.. Perhaps I should put something together myself - always get confused with all the stuff I want to add, change, adjust, and make better. Regards Adam Loving The Duchess The Defender 110 TD5 XS My Defender story - http://www.defender2.net/forum/topic64005.html |
First MOT due Friday,
Little bit worried, nothing in particular, just first time on defender... Did my checks as per the pre MOT thread, Chassis is in Alright condition for 15 years, but that could soon deteriorate, so i think i'll have it taken back and dinitrolled. One odd thing whats this hanging thing from the bottom of my second axle? Click image to enlarge I'm on IG: https://www.instagram.com/osloblue42/ Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html ![]() |
Im sure itll be fine. Wishing you good luck, just in case. Regards
thanks both.
It is regretful that it is going to cost me a lot of money... because it passed! Yay! In good nick for 90000 Miles and 15 years, "Much better than Some TDCIs with a third of the mileage!" Slight leak on rear diff though! Click image to enlarge I'm on IG: https://www.instagram.com/osloblue42/ Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html ![]() Last edited by OsloBlue on 23rd Nov 2018 3:49pm. Edited 2 times in total |
Fantastic news!!
Good luck with the leak fix. Regards Adam Loving The Duchess The Defender 110 TD5 XS My Defender story - http://www.defender2.net/forum/topic64005.html |
| L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11096
+1
Worked out the average MPG: 25.12 Mpg
That looks well clever! Is that an app or something?
Your average is better than mine... im on about 21mpg Adam Loving The Duchess The Defender 110 TD5 XS My Defender story - http://www.defender2.net/forum/topic64005.html |
Yip, only problem is it only input in gallons. I'm on IG: https://www.instagram.com/osloblue42/
Woe unto Woe.
Sorted out the strikers on my doors today, better than usual, bit of a pain when all the spacers are missing on the 2nd row, 2Pence peices to the rescue. Unfortunately uncovered the nearside second row central locking and manual lock wasn't working. Had to tear the door card off to get at the actual mechanism. Not an easy job, unlike the front. Especially when the heavens open up. At least she locks now. Also Painted the rear crossmember in rustoleum straight to rust. Also notices one of my rear door hinge pins is missing... I'm on IG: https://www.instagram.com/osloblue42/ Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html ![]() |
After having my car serviced and finding out i need a new ABS unit it also came to the attention of my guy that the rear brake pads were wrong.
Apparently they come in Two thicknesses and i require the thicker of the two but i have the thinner of the two, so i only have 1mm of working pad left before they're completely worn and have no contact... I also have a leak on my rear diff apex seal... On the plus side my window wiper jets are now functional I'm on IG: https://www.instagram.com/osloblue42/ Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html ![]() |
| All times are GMT |
