Home > Td5 > Replacement front TD5 disk brakes - |
geobloke Member Since: 06 Nov 2012 Location: Nottinghamshire Posts: 4388 |
Ok, I may be able to help here. I have used both the Britpart drilled and grooves and WBC dimples and grooves vented discs in my TD5 110.
I went from standard to Britpart and had them fitted for five years worth of driving (married to EBC pads). They were brilliant, can’t fault them at all. Noticeably better than the standard discs under hard braking and didn’t fade as quickly as the standard discs when working hard with trailers attached or steep switch back descents. They came to the end of their life about 12 months ago, when I swapped to EBC discs and pads on the front. The difference between them... not noticeable at all...! Time will tell how Worthwhile the anti corrosion coating is worth... £100?! Probably not... Incidentally I have the Britpart non vented drilled and grooved discs on the rear and when they bite they stop the behemoth that is Miffy like she has just had an anchor deployed from the rear cross member...! The only issue is that EBC do not do a pad for the rear of the 110, only the 90. My next pads will be Brembo pads as they do a 110 specific pad. I believe I have photos of the install some place if you are interested... |
13th Sep 2019 11:30am |
alexatnd Member Since: 19 May 2015 Location: Yorkshire Posts: 249 |
Many many thanks for this. Britpart it is for next set of disks which do need replacing real soon nowish.
Going down really steep hills in French alps with fully laden 110 including 5 bikes on the back and tandem/roofbox on top really needed better brakes. Rgds Alex Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb Gertie - 1999 110 TD5 - like a Phoenix from the ashes back on road... almost Effie - 2004 110 TD5 County |
13th Sep 2019 12:00pm |
There is talk on these forums that in addition to uprated discs and pads replacing the DOT4.1 brake fluid with DOT5.1 makes for a much firmer pedal and less chance of boiling the brake fluid.
13th Sep 2019 12:02pm |
o.k. Effie just had a full fluid change a few months ago. Gertie .. I'll change when I put the new disk on
Thx A Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb Gertie - 1999 110 TD5 - like a Phoenix from the ashes back on road... almost Effie - 2004 110 TD5 County |
13th Sep 2019 12:27pm |
