![]() | Home > Maintenance & Modifications > LT230 Ratios |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2347 ![]() ![]() ![]() |
Having researched myself into a bit of a pickle I am after the benefit of your experience.
A transfer box rebuild is on the cards, so looking in to changing the ration while I'm there. Or not, whatever the outcome of this thread may be. 2.4 TDCi 110, BAS map and 33's... Which ratio? 1.1, 1.2, 1.3 or 1.4? And why/what is the benefit? Thanks > 110 XS Double Cab |
Sooooo not a TDCI but a TD5 110 with 33s and an IRB remap;
Returned back from a 1:1.2 (Discovery gearing) to the standard 1:1.4 (Defender gearing) because the extra weight of the cage, roof rack and gear makes the shorter gears make sense. The Defender is now so much easier around town and doing hill starts (lots of those hills up here in NW) and the super bonus is that the EGTs are 100 or so degrees lower than before at 60 and 70 mph. Really the only down side is the slower top speed on the motorway, due to the noise mostly as it will pull and pull if necessary. I plan to fit an overdrive to compensate for this though. |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2217 ![]() ![]() ![]() |
1.3 best of both worlds. Love mine to bits. Happily cruises at 70 "as if its 60" and so forth
Waldorf Member Since: 13 Aug 2019 Location: Aalter Posts: 12 ![]() ![]() ![]() |
First question should be: what do you want to achieve? How do you use the car? The Puma has the 1.2 transfer box, so anything shorter will be undergeared.
Vehicle's predominant use is around town with some motorway. Occasional off road and towing.
I think I might be approaching this the wrong way round actually. So factory is 1.2... If I move to 1.3 or 1.4 then output revs decrease at the same engine speed. So first becomes shorter and motorway cruising speed engine revs higher. If I move to 1.1 then output revs increase at the same engine speed. So first becomes longer and motorway cruising speed engine revs lower. Around town I find I am between third and fourth a lot. Plus first is so short, and reducing motorway cruising revs would be a bonus. So, perhaps moving to 1.1 would achieve this? Perhaps I'm overthinking this and the 1.2 is the best compromise? Thoughts welcome! > 110 XS Double Cab Last edited by hank on 13th Sep 2019 9:11am. Edited 1 time in total |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6015 ![]() ![]() ![]() |
Ashcrofts have a calculator on their website that will show rpm vs mph which might assist you? 1999 Defender TD5 110
https://www.ashcroft-transmissions.co.uk/calc/ratio_calc.html 1999 Defender TD5 110
Just checking here as I do not actually know the answer. Did the Puma come with 1:1.2 as standard or a 1:1.4 like the TD5s did as standard? |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2363 ![]() ![]() ![]() |
Move to 1.3 or 1.4 - high box gearing is lower- more revs on the motorway- first gear is lower so easier to pull away with a heavy load on a steep hill.
Move to 1.1 - high box gearing is higher - less revs on the motorway - first gear is higher so less easy to pull away with a heavy load on a steep hill HTH Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
Puma comes with 1.2 as standard.
Thanks Mo
Thanks I hadn't seen that. 1.2 ratio, 6th gear @ 80mph = 2593rpm 1.1 ratio, 6th gear @ 80mph = 2356rpm -237rpm difference. 1.2 ratio, 1st gear @ 10mph = 2378rpm 1.1 ratio, 1st gear @ 10mph = 2160rpm -218rpm difference. Worth it? > 110 XS Double Cab |
Really depends on how many motorway miles you do, that's where you'll see the difference I suspect.
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1247 ![]() ![]() ![]() |
I've had a 1.2 transfer box in my 300Tdi 110 on 32" tyres for the last decade or so and wouldn't go back to a 1.4 although I do do long motorway journeys. The only minor downside is that first is quite tall now (but they dropped first on the Puma) and that makes hill starts with 3.5 tonnes behind you a little tricky.
I've found that with the 1.2 it's moved the gears into more optimal locations. A gentle pootle around town and it's basically 3rd gear all the way. If you go out into the countryside and move along a little faster then 4th is the main gear. Cruising along the motorway then 5th. If you've got 3.5 tonnes behind you on uphill motorway stretches then 4th is ideal at 60mph and sits about the same as 5th used to (with the 1.4) at 70mph. Interestingly quite a few years ago I went to a clay competition (when I lived in Surrey and he was still from back in South Wales) so we met up at the shoot in Bicester. Both joined the dual carriageway back down to the M4 and he commented afterwards that he (in a 2.4 Puma) struggled to keep up with me. Since then I've snapped two crankshafts but the last build with a lower half from someone in Devon has obviously had the pump tweaked a fair bit. I had previously been thinking about fitting a VNT to help with bottom end boost for when towing with the 1.2 but that simple tweak has utterly transformed the vehicle. Retroanaconda and I have discussed this at length and the main benefit which isn't often described with the move to 1.2 is that, certainly for me, it moves the gears into nicer positions. E.g. 60mph is quite comfortable for long periods in 4th which means that you've got the strongest (at least in the R380) gear for towing. 5th effectively becomes an overdrive but not quite. Although the 300 has so much more torque now that I'd even consider an overdrive to drop the revs even more on the motorway, having said that the noise is probably mostly my KM2s... Ed 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
