Home > Maintenance & Modifications > LDV mirrors?
eutek
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
LDV mirrors?
I was reading in a Land Rover magazine over the weekend that someone fitted the mirrors from an LDV van, as they're more or less a direct swap and offer better visibility because of the larger size.
Has anyone else ever done/heard of this?
Post #79097 5th Jul 2011 2:09pm
Larger Mirrors vibrate like fook if you want to try some pm your address I have some you can have even wired for heat Thumbs Up
Post #79098 5th Jul 2011 2:48pm
LR90XS2011
type Bolt on Bits into your search they used to do them DEFENDER 90 TDCI XS,
Post #79116 5th Jul 2011 4:38pm
sc70
Wales 2015 Defender 90 Puma 2.2 CSW Santorini Black
second that Thumbs Up
Post #79130 5th Jul 2011 7:22pm
Tazz
Re: LDV mirrors?
I had a look into it and found that it's the mirrors off the old Leyland Daf Sherpa c 1980s, not the more recent LDV 200s or 400s. Having checked on a LDV forum (yep they have a forum for LDV van nuts) it seems the only likely way of getting hold of such mirrors is through a breakers.
There are companies who sell larger mirror heads for the Defender, including some with unbreakable surface and some heated. I've read mixed reports - some claiming they're the best thing since sliced bread; others complain about the amount they vibrate and yet others who say the head continuously droops.
Unless I could get some free to try I think I'll stick with the originals as £40 is a lot of money to find out they're no good.
Taz
Post #79237 6th Jul 2011 4:25pm
Merlin
I fitted some larger mirrors, so I don’t have to fit extended mirrors while towing our caravan. Normally they are tucked in, but I push them out, when I’m towing and they show all down the side of the caravan. They do vibrate a bit more than the standard ones, but not that you would notice. I’m told all I bought from one of the 4x4 retailers in LRO, is Wolf mirrors and arms that are still a standard item. So perhaps a call to a stealership’s parts shop is in order.
Beware that the fixing screws are different from the ones in the standard mirrors and may not come with the mirrors. Also you will have to take off the top hinge, which means supporting the door while you do it, otherwise it will rest on only one hinge which isn’t a good idea at all.
Merlin.
Post #79245 6th Jul 2011 5:06pm
