Home > Puma (Tdci) > Propshaft bolt special tool
pannawonica
Australia
I have been looking at the special extension tool for removing propshaft bolts.
It is listed as 9/16 inch for defenders, however it is not specified for the Puma
The idea is for complete greasing and examination which is not so easy on vehicle. Question is will it fit the Puma?
Post #79046 5th Jul 2011 5:20am
AndrewS
We use a 9/16 spanner. 130's have feeling's as well you know Smile
Post #79049 5th Jul 2011 8:06am
ibexman
YES Thumbs Up
Post #79057 5th Jul 2011 8:56am
TJ101
Well worth the money,, saves loads of time with a air gun / 18v impact
I bough 2, 1/2 inch and the 3/8,, due to sod's law,,so never lost one California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #79059 5th Jul 2011 9:07am
pannawonica
Australia
Thanks
Many thanks I was not sure ! Thumbs Up
Post #79085 5th Jul 2011 12:04pm
noworries4x4
Yes Land Rover even in the 21st centuary still uses unf nuts and bolts for their propshafts, nothing like putting your head in the sand. 10mm fine high tensile probably a bit to high tech for Lode Lane. Ir you don't want to invest in a special socket just grind the outside edge off an old 9/16 ring spanner i've got one in my tool box made years and years ago. If everything is under control you are not going fast enough.
Every Day MY 20 Discovery 5 Commercial Workshop and Escort Vehicle
Weekends MY 12 L322 4.4 TDV8 Vogue
No Worries 4X4
Post #79403 7th Jul 2011 9:45pm
noworries4x4
No Worries 4X4
Post #79404 7th Jul 2011 9:45pm
pannawonica
Australia
Grinding a ring down, yes that is an idea, however I am more inclined to think that if it is easy to do I will be more inclined to do it. The iron ore dust here is quite abraisive, when wet it is worse and drying it sets like concrete!
It will make the investment in a 9/16 spanner and the special tool, already dug out the grease gun I,m halfway there.
Thumbs Up Laughing
Post #79439 8th Jul 2011 2:19am
