Home > Maintenance & Modifications > Who has the Gwyn Lewis front mudflap kit?
Co1
Have bought this kit, but not sure how it will look, so would appreciate any pics if anyone has them fitted before I start cutting wheel arches.
Col
Post #789702 31st Aug 2019 11:45am
Co1
Should add, it’s the front mud flap kit.
Post #789704 31st Aug 2019 11:57am
Romadog
Me ! Thumbs Up
Post #789709 31st Aug 2019 12:34pm
Co1
Cheers Romadog Thumbs Up
Post #789710 31st Aug 2019 12:46pm
donmacn
Me too - any particular questions, or did Romadog's picture sort it out? Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #789711 31st Aug 2019 12:48pm
Jimb1978
England 2002 Defender 110 Td5 Black LE Java Black
Me too. They are great although I was a bit reluctant to cut a strip off the wheel arch. I felt this should have been in the description on the website. Still, I’m glad I fitted them. I fitted offset wheels and the corrosion in just one winter inside the rear doors was awful. Fitted these and problem solved 2002 110 td5
Post #789712 31st Aug 2019 1:07pm
oneten110
Got them at both ends, far better than the Land Rover offering, especially when used in conjunction with the plastic flaps which protect the footwells and the rear cross member.
All fittings and fasteners are either stainless or galvanised. A well thought out piece of kit.
The rear flaps mounting system is far more robust then the LR system and the flaps are QD.
 It is not a Defender, it is a One_Ten
Post #789715 31st Aug 2019 1:26pm
Co1
Excellent, much appreciated. Will get them fitted once the rain stops!
Post #789721 31st Aug 2019 1:39pm
jeffersj
United Kingdom 1996 Defender 90 300 Tdi HT Bronze Green
Me too, saves all of the crap going up the doors. Jeff
Ex 1968 Series 2A
Ex 90 TD5
Ex D3
Ex D4
Post #789894 1st Sep 2019 4:24pm
Co1
Done. Pleased with them all and simple enough to do.
Post #789898 1st Sep 2019 4:54pm
oneten110
All you need now is the matching set for the back. If anything they are even better thought out. It is not a Defender, it is a One_Ten
Post #789910 1st Sep 2019 6:04pm
Call me dumb.... but I thought the GW flaps were supposed to stop the spray up the side of the vehicles? Laughing Shocked Question Question
Post #789920 1st Sep 2019 6:59pm
Co1
The spray was there before the mud flaps were moved!!
Post #789923 1st Sep 2019 7:04pm
ericvv
[quote="diesel_jim"]
Mudflap extenders are the perfect answer to that. That means as long as you don’t run wider than 235 tires.
Eric
Standard
Extended
 You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #789926 1st Sep 2019 7:09pm
The GL product is great but can give problems if you run larger tyres (eg 255/85 X 16) and want to fit tyre chains.
Ericvv, can I ask who supplies those?
Post #789929 1st Sep 2019 7:22pm
