Home > Maintenance & Modifications > Which led headlamps
Stacey007
Which led headlamps
Ok so it's getting darker quicker already..
I've crystal lens with upgraded bulbs but still compared to modern lights they are poor.
Ideally I would like a set that surrounds are black.
I hear I need specific marks on them to pass mot.
Even some Landrover suppliers have them from £90 a pair up to £600 or more?
What have you got? Pic if poss and roughly how much they were / are you happy with them.
Thanks
Post #789445 30th Aug 2019 8:39am
Pilgrimmick
Watch with interest, this has been done to death in the past, but with new products coming onto the market all the time then there must be some good lamps that are affordable that have not been reviewed previously. 80" 1948
Lightweight V8
Bowler Tomcat
130 Station wagon
90 300tdi
(Santana PS10 pick up)
Range Rover L322 (Ful fat)
Post #789446 30th Aug 2019 8:46am
Bluest
I would recommend trying them before you buy. I’ve got Trucklites and I’m a bit disappointed in them. Plus, they freeze over in winter. In hindsight I preferred my old set up of a relay loom, Crystals and Osram Nightbreakers. 2007 110 TDCi Station Wagon XS
Post #789447 30th Aug 2019 8:46am
rallysteve
My Wipac Crystals, Osram Nightbreaker Unlimited bulbs and headlight relay setup gives pretty much the same amount of light as my Audi's Xenon lights.
What bulbs are you using and have you got relays installed?
Post #789450 30th Aug 2019 9:05am
AJC
I have the revised Trucklite from 4x4 overlander and I think they're great.
main reasom I went for them is because they don't stand out as an LED light. Just look standard with a dark tint
Post #789452 30th Aug 2019 9:15am
Stacey007
I have crystals, Philips upgraded bulbs but I never fitted the bloomsburg loom? (although do have it)
I'm surprised if the loom will make these as good as previous cars with LED xenon lights?
Seems Britpart Lynx get good reviews... but britpart...
The choice now is massive... The rice range massive, even if you leave out all the chinese ones, the range at suppliers is £150 to over £600
Difficult to try before I buy.... Need to fit them and drive down my local country lanes at night to compaore Thumbs Up Its not as if they give the same technical details in the specifications so hard to just choose on that...
Mindfield....
Big Cry
Post #789457 30th Aug 2019 9:41am
Pilgrimmick
I am willing to try out any new lights and give out unbiased opinions. Nolden etc take note😂
It is difficult to judge from the figures, at one time you used to get comparison diagrams of beam spread and reach, these seem to have been dropped from sales details.
Sometimes just easier putting on LED spots to use with main beam. 80" 1948
Lightweight V8
Bowler Tomcat
130 Station wagon
90 300tdi
Post #789459 30th Aug 2019 9:48am
windy81
Wales 1992 Defender 90 200 Tdi HT Firenze Red
Steve
this ^^
Wire the lights directly to alternator. Makes a huge difference and although I haven't ever had LED on my Landy, I can't see much difference if I did.
Post #789465 30th Aug 2019 10:07am
Ramsay
Scotland 1995 Defender 110 300 Tdi CSW Auto Keswick Green
Stacey007 if you are not using a headlamp relay then you are only getting about 3/4 of the volts you could do at the lamps. Check the Boomslang? Loom you have and fit it.
If you go to LED the voltage at the lamps is not relevant to the brightness. However the main headlamp switch will eventually still burn out. It will just take longer with the lower load. 1995 Defender 110 CSW
1971 SIIA Lightweight
Post #789485 30th Aug 2019 11:32am
Naks
TruckLights Thumbs Up --
Post #789491 30th Aug 2019 11:58am
Notyalc
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
Relays and upgrade bulbs are more than enough for me
Post #789496 30th Aug 2019 12:14pm
Not_Given
United Kingdom 2011 Defender 110 Puma 2.4 SW Orkney Grey
JW Speaker Evo Dual burn now have an option for heated glass. It’s automatic at low temps.
NG
Post #789519 30th Aug 2019 2:43pm
Devon-Rover
Trucklite as they kinda look standard
 Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
Post #789662 30th Aug 2019 11:27pm
Bluericky
United Kingdom 2009 Defender 110 Puma 2.4 DCPU Keswick Green
Also went for the Truklites , they seemed to be a well established company compared to some and it sits well that they’re also used by the American military on some vehicles. E marked and straightforward to fit .
As above poster has said , they don’t look too different to the standard lights unless you go for the smoked glass.
My one criticism is lighting cut off on the periphery of the beam , it’s so sharp that it can be a rather distracting but you do get used to it.
I think mudstuff have them on offer at the mo
 https://www.instagram.com/hustynminepark/
Post #789666 31st Aug 2019 12:28am
CharlieDonuts
France 2008 Defender 90 Puma 2.4 SW Galway Green
I bought some cheap ones (I dunno if I should say where from). I bought them to see what they looked like mostly. I didn’t like the look and they failed a headlamp test (outside the zone) so I fitted Crystals Nightbreakers and which for the moment I am happy with. Will do the wiring upgrade when I have acquired the competence to do so. I would avoid cheap LED lamps if I were you !
Post #789671 31st Aug 2019 8:17am
