Home > Maintenance & Modifications > Heater fan control lever assembly
RRUK
The heater control lever assembly in my second Wolf is all a bit broken. It seems there is a plastic trim panel to the outer side (facing into the car - passenger) and the whole thing is attached with screws into the dash assembly.
Mine is all wobbly as it has numerous cracks, so there is nothing anchoring the slider control, making it impossible to switch the fans on.
My question is - is the plastic panel replaceable or do I need to replace the entire part (STC4848)?
https://rimmerbros.com/ItemImages/Large/364943-Large.jpg 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #789163 28th Aug 2019 4:02pm
dorsetsmith
MUC 2808 RHD or MUC 3023 LHD
have seen metal replacement
Post #789172 28th Aug 2019 4:45pm
RRUK
That is the metal dash assembly for the entire dash isn't it? 2016 D4 HSE
Post #789173 28th Aug 2019 4:50pm
dorsetsmith
do you mean this
Post #789176 28th Aug 2019 5:03pm
RRUK
Yep, part no is STC4848, looks like an entire replacement part is required 2016 D4 HSE
Post #789181 28th Aug 2019 5:28pm
dorsetsmith
you can take it a part but if plastic part broken hole thing has to be replaced
Post #789183 28th Aug 2019 5:49pm
RRUK
So i ordered the new part and it arrived today, yet it doesn't come with the plastic trim side panel after all that. Brilliant!
I can't find a separate part number for it. 2016 D4 HSE
Post #790062 2nd Sep 2019 12:50pm
Green Machine
Do you mean the trim cover for the temperature blend lever (which is also the end of the dash)? Possibly one of these?
MWC9338PMA
MWC9339PMA
Isn't the fan speed lever cover part of the instrument binnacle and surround? (At work, so haven't got my vehicle to check against!) 2005 Td5 | 90 Station Wagon | Tonga Green
Post #790070 2nd Sep 2019 1:22pm
Green Machine
Doesn't the fan lever just stick out of a slot / gap between 1 and 10 below?
As this (stolen from African Uhambo here: https://africanuhambo.co.uk/2012/05/30/ins...ineering/)
Post #790071 2nd Sep 2019 1:26pm
RRUK
I'll take a photo of it, it may help. I believe the fan control screws onto the side of part No 1 above, and has a plastic trim over it to make it look pretty, much like on the temp blend lever side. 2016 D4 HSE
Post #790073 2nd Sep 2019 1:28pm
Green Machine
I think the fan speed lever assembly is screwed into the inside of Part no. 1. So the outside face that you're looking at is actually part of the instrument binnacle surround. Could be wrong.
Also you might as well consider replacing it with the steel version from Raptor (as in blog link above). Saves it breaking up again. 2005 Td5 | 90 Station Wagon | Tonga Green
Post #790074 2nd Sep 2019 1:31pm
Mo Murphy
There is no plastic cover on that side. What you are seeing is the part that Dorsetsmith has linked to in his first post.
This part commonly breaks up and a plastic replacement will fare no better in time. Raptor do a metal replacement which is much better.
Easy enough to replace just takes a bit of time to dismantle and reassemble.
HTH
50 Shades of Pennine Grey
Post #790087 2nd Sep 2019 2:41pm
RRUK
After much scratching of head and looking online, it seems I need the large part 1 on the diagram, it has all the supports. Mine being ex MOD looks like half of it is missing, probably an in the field repair.
Raptor Engineering do a steel version and a how to video so I'm off to watch that and then order one.
Thanks for all your help. 2016 D4 HSE
Post #790088 2nd Sep 2019 2:43pm
RRUK
Mo, SNAP!
We crossed in the post.
Thanks Thumbs Up 2016 D4 HSE
Post #790089 2nd Sep 2019 2:43pm
Mo Murphy
Here's one I prepared earlier Wink
Been in a few years now.
Post #790090 2nd Sep 2019 2:46pm
