Home > Td5 > Quewstion about keys |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5416 |
A 04 reg Td5 will/should have one key that will do everything apart from stupid locking fuel filler cap.
16th Jul 2019 11:32am |
alexatnd Member Since: 19 May 2015 Location: Yorkshire Posts: 249 |
According to the parts dept at our local land rover dealer, it should have 2 keys one for ignition one for doors and they only get key blanks which are then cut to fit the lock ..... so I'd need new door locks Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb Gertie - 1999 110 TD5 - like a Phoenix from the ashes back on road... almost Effie - 2004 110 TD5 County |
16th Jul 2019 12:44pm |
... and according to localland rover parts supplier, as of 2002 it 1 key for everything Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
16th Jul 2019 12:53pm |
Ehhhh. So it’s 2004, so one key as it’s after 2002, why is parts man saying two keys?
Just charge, jump, provide power via the connection to the starter motor, or via tow socket if you have one. |
16th Jul 2019 2:02pm |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 898 |
🤔. Hmmm I have 99 110 ROW and it has but one key! Not sure what is going on with yours? 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
16th Jul 2019 2:48pm |
dailysleaze Member Since: 23 May 2013 Location: United Kingdom Posts: 237 |
depends if the door locks and/or ignition switch have been changed previously
16th Jul 2019 8:02pm |
Landish Member Since: 19 Jun 2018 Location: UK Posts: 74 |
My 2005 Td5 has one key that fits the ignition, driver’s door and tailgate. There’s no keyhole on the passenger door but the central locking works on both sides. Like everyone else, my fuel filler cap has a different key . . . . 2005 Defender 90 TD5
17th Jul 2019 6:51pm |
I suspect the steering column barrel was changed at some point. It's about £80 for a new set of ketys and barrels, so gues I'll do that at some point.
As for getting in 1). No direct power feed via trailer socket so couldn;t apply battery power that way 2). There must be a relay between starter motor and rest of electrics as disconnecting starter motor connections and connecting new battery there didnl;lt work either. 3). Eventually used oldest trick in the book to open the drivers door. As soon as I connected up a new battery she strted 1st time and has beenfine since then Rgds Alex Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb Gertie - 1999 110 TD5 - like a Phoenix from the ashes back on road... almost Effie - 2004 110 TD5 County |
18th Jul 2019 1:29pm |
RILEY Member Since: 01 Feb 2013 Location: United Kingdom Posts: 35 |
I have a 1998 defender and use a spoon to get in
or any key one life, sell it |
22nd Aug 2019 9:39pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1568 |
I think when they started doing the “one key” it was maybe the county models that had that first seemed that way when I was working on them?!
24th Aug 2019 5:58pm |
