Home > Wheels & Tyres > Novice - Change Boost alloys to Steel modular
Dagonet
United Kingdom 2009 Defender 90 Puma 2.2 HT Java Black
Hi Folks,
I want to switch a set of Boost alloys for these steel modular wheels.
https://www.4x4tyres.co.uk/16-tuff-torque-...6508tgbmod
Do I need to change the hubs? What sort of nuts do I need to get? What are the pitfalls?
Thanks in advance wise ones.
Post #788028 21st Aug 2019 11:37am
pux146
As long as you get he correct fitting PCD you will be fine. Then you will have to get Steel Wheel nuts, as your existing alloy wheel nuts will not work with these steel wheels. 2007 2.4 90 fettled & remapped.
Post #788036 21st Aug 2019 12:37pm
Dagonet
Thanks chap.
Post #788038 21st Aug 2019 1:26pm
JOW240725
Good choice, as above just need a set of steel wheel nuts.
Being ET0 don't forget to adjust your steering stops to improve your turning circle. Thumbs Up
Oh and don't forget to post before and after photos Whistle James
Instagram @suffolk_rovers
Post #788054 21st Aug 2019 4:47pm
2010Blackdefender90
United Kingdom 2011 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
Thought you could use alloy wheel nuts on steel rims, but not steel nuts on alloy wheels?
Post #788207 22nd Aug 2019 10:14am
Martin
Site Admin
You can use alloy nuts with steels (for example to use a steel spare in place of an alloy), but they look a bit odd and sticky-out.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #788208 22nd Aug 2019 10:15am
2010Blackdefender90
Right, thought so, agreed, though
Post #788209 22nd Aug 2019 10:17am
Dagonet
Thanks for all the advice folks. I'll be sure to post pics when the transformation is complete.
Post #788246 22nd Aug 2019 3:24pm
epictrail
United Kingdom 2004 Defender 110 Td5 HT Chawton White
Post #788283 22nd Aug 2019 6:28pm
mobilesawmiller
Good choice of rims. IMHO steel modular rims are the dogs dangly bits for a Defender!!
Post #790741 5th Sep 2019 6:48pm
