![]() | Home > In Car Electronics > Rear Speaker Connector Type |
| V8Simon Member Since: 17 May 2016 Location: Prestatyn, Wales Posts: 154
Hi gang,
I'm about to finally install some speakers in to the rear of my 90 and would prefer to buy the right connector to fit the speaker wires to and click to the the existing (femail) one under the bonnet. The existence of the connector has been covered lots but I can't find the right type to purchase. I think they are TE Connectivity Econoseal ones but can I find one that looks like it would connect to the one in the photos and this one, unlike others, doesn't have any numbers on it to assist. Its a 4 way connector, RS have them here -> https://uk.rs-online.com/web/p/automotive-connectors/6806970/ If anyone has a better understanding or point me to the right product, I'd be so happy...... Click image to enlarge 1984 90 V8 puma want to be. |
| rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2242
It is a sumitomo HW series connector, not very easy to obtain in the UK. Paul MC on here will be able to supply terminals and might be able to supply the connector housing.
If not you are best ordering from Japan from a company called Eastern Beaver. Be aware of their minimum order value though. Cheers, Steve 02' 110 TD5 Double Cab Rebuild Thread |
You are in luck
https://www.simtekuk.co.uk/product.php/4_w...:::1570419 Steve 02' 110 TD5 Double Cab Rebuild Thread |
lol, thanks, now ordered!!! 1984 90 V8 puma want to be.
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20939
I've used Simtekukbefore with good results - should sort you out with the connector no problem.
____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
Thanks to Custom90Steve and RallySteve, the connector part from Simtekuk arrived at the weekend and is spot on. I just now need to install and wire up my rear speakers!!!
Thanks Chaps. 1984 90 V8 puma want to be. |
